Author Topic: Air filter ???  (Read 1606 times)
Offline Dirtydog
Air filter ???
« on: 26 January 2013, 08:25 »
Hi guys I have a gti 18 turbo remapped , boost valve decat pipe and chipped but does not have that flutter sound to it I met a guy another day he's gti turbo was big standard but had a lush flutter sound to it when revved can anyone give me a name off filter that does this ? And do I have to change whole pipe or just filter on the end cheers ????
Scotty ,my ride is a 2000 plated 1.8 gti turbo .forge dump valve. Decat 6" downpipe. Stage 2 chipped and remapped by AMD . Piper cross air induction totalling 205 bhp of fun at the wheels !
Re: Air filter ???
« Reply #1 on: 26 January 2013, 09:07 »
Running an induction kit will help, have a look at the toyosports ones on ebay but run a better quality filter.
Offline Screech16v
  • MK3 20vt AGU
Re: Air filter ???
« Reply #2 on: 26 January 2013, 18:16 »
My 1.8t used to flutter,quickly becomes very annoying tbh, I run a pipercross cone , I changed the standard valve for a forge 008 and now get a nice ptish, turned out my standard valve was fubarred the diaphragm was holed so maybe the flutter is not a good thing.
Offline Dalo Harkin
Re: Air filter ???
« Reply #3 on: 27 January 2013, 07:48 »
some people just put the cone on the MAF but you will get heat soak so you need a shield of some kind on it
 the alternative is the Toyo one but it sits behind the bumper so any large puddles and you risk water on the filter
 if you have a standard dump valve you won't get much ' blow off' anyway, get a forge 007p with appropriate spring (yellow on a stage 1 I think)
