Golf mk3
hardmonkeys
Which handbrake cable?
Topic: Which handbrake cable? (Read 1744 times)
Khare
Serious forum addict
The bear that khares
25 January 2013, 21:27 »
choice 1
choice 2
choice 3
choice 4
1995 GTI
Khare
Re: Which handbrake cable?
25 January 2013, 21:32 »
Pretty sure it's choice 4. The cable has a small rubber boot on the caliper end, so it's either choice 2 or 4, but the boot on choice 2 seems short compared to pics of the current ones.
Screech16v
MK3 20vt AGU
25 January 2013, 21:44 »
I would think either 2 or 4 myself,both of them would probably fit,i would get a pair as they are cheap,might have to get some myself as im sick of the cables freezing up.
Khare
25 January 2013, 21:49 »
Mine are just on the limit of tightness, and they barely hold the car on a hill, so in need of urgent attention. Think I'll go for choice 4 as they're the correct ones.
spikenipple
25 January 2013, 23:25 »
Yeah number 4 is the right one for your car. I bought the 1616mm cable instead of the 1624mm cable and had to turn the adjuster nut down to get it to fit
Khare
25 January 2013, 23:26 »
Excellent
£60 worth of bits ordered
Including a 20mm holesaw...Who can guess what that's for?
spikenipple
Reply #6 on:
25 January 2013, 23:34 »
Are you going to use it....to cut a 20mm hole?
Khare
Reply #7 on:
25 January 2013, 23:46 »
Correct! 5 points to you sir.....And a bonus one for being obvious!
I'll give you a clue. Galvanized rubber.
Bellend
Reply #8 on:
26 January 2013, 01:08 »
Engine raise?
Where all my moneys went.
Khare
Reply #9 on:
26 January 2013, 09:27 »
Hockey puck engine mount.
Golf mk3
hardmonkeys
