Author Topic: Engine Management Light (Again)  (Read 1713 times)
Offline stfc_gti
« on: 25 January 2013, 10:31 »
OK, So i have been having a few issues with my golf as some of you may know, most of which have now been sorted, or atleast i though. But this bloody EML keeps lighting up for no aparent reason.
I've had my mechanic look at it, he scans it for codes, nothing untoward shows up, clears the codes, clears the EML and off i go.
Would it be worth me investing in a fault code reader myself? Will this enable me to clear the EML myself rather than keep going to my mechanic? If so, Is there any specific code reader i shuold go for?
Thanks
2002 1.8T GTI AUM, Standard (not for much longer)
Offline MPJ88
Re: Engine Management Light (Again)
« Reply #1 on: 25 January 2013, 11:05 »
can buy cables from ebay and lite version of vcds which will allow you to see fault codes and clear them
However if the light keeps popping up it indicates something is wrong!
Offline stfc_gti
« Reply #2 on: 25 January 2013, 12:21 »
I agree, but until i have the time to figure out why, i will just go with plan b :-)
Offline BarryMKIV
« Reply #3 on: 25 January 2013, 15:09 »
I got my scanner from Autel Tech, it's a great bit of kit too. Vital piece of kit for any MK4 owner IMO.
25th Anniversary GTI 1.8T No. 0441
Online barrym381
« Reply #4 on: 25 January 2013, 15:18 »
Offline stfc_gti
« Reply #5 on: 25 January 2013, 15:37 »
buy a cheap code reader they can clear eml  :smiley:
http://www.amazon.co.uk/U281-OBD-2-CAN-BUS-SCANNER-SKODA/dp/B001C9V89A
was looking at that one on ebay, but you just saved me 5 squid, nice one
Online barrym381
« Reply #6 on: 25 January 2013, 15:50 »
I always keep 1 of these in the car  :smiley:
Offline itavaltalainen
« Reply #7 on: 25 January 2013, 23:22 »
would help if the "mechanic" would actually bother to tell you exact fault codes....
knowing the exact fault code does a lot to diagnose fault correctly!
Offline Dalo Harkin
« Reply #8 on: 26 January 2013, 08:16 »
you mention some issues, can you expand on that ?
Offline stfc_gti
« Reply #9 on: 26 January 2013, 12:32 »
The issues are sorted, so its not really relevant, but ive recently had stat/temp sender/water pump/cambelt replaced and most recently a boost issue where a pipe had come loose.
But now im not having any issue that i can feel, car is running very well, not boost issues, no power issues, apart from this bloody EML keeps popping up every now and again for no apparent reason.
