Author Topic: Locking switch on the door card for a R32 faulty  (Read 1251 times)
Offline RAIDEN
« on: 24 January 2013, 14:05 »
My door when I push the button to lock and unlock the doors does not work most of the time so I think its on its way out. Is it easy to fix? Otherwise in march my MK 5 is getting serviced so should I get them to fix it. Would anyone know what I mite get charged?
Offline dTEA
  • back in an MK5
Re: Locking switch on the door card for a R32 faulty
« Reply #1 on: 08 February 2013, 23:22 »
If its just the switch easy enough to change. Pretty sure its a door card off job though from memory. Search for mk5 or 6 door card removal to show you and there is a nack to the amount of brute force required that doesn't pop the door clips. 1/2 labour would be normal plus parts if the garage does it for you.
Edition 30 / T5 T32 Kombi
Offline Holepunch
« Reply #2 on: 11 February 2013, 11:30 »
I replaced mine last weekend in under an hour.
