Author Topic: 4motion brakes 312mm  (Read 1446 times)
Offline Glenryck
  • V6 4motion r32 body kit r32 miltek cat back 19" oz
« on: 23 January 2013, 23:50 »
Hi all does the v6 4motion have 312mm brakes as standard mine are a bit lacking in bite unless you jump on them hard. Would it be worth paying out for  set of cupra brakes or r32 or just getting the old ones overhauled any ideas cheers. :huh:
Offline navmk4gti
Re: 4motion brakes 312mm
« Reply #1 on: 24 January 2013, 00:16 »
I believe they are 312mm at the front and 256mm at the rear. decent discs aint Cheap bud. You should get brakes checked out before spending on new set of discs :wink:
Offline jonrandom
« Reply #2 on: 24 January 2013, 07:26 »
Just getting decent pads, braided lines and decent brake fluid can make a lot of difference.
Offline damien010685
« Reply #3 on: 24 January 2013, 10:53 »
I have standard 4mo brakes with pagid disks and Brembo pads and they work very well suggest get better pads etc as jonrandom said
Offline navmk4gti
« Reply #4 on: 24 January 2013, 12:54 »
Where you get the discs from mate. My front ones need replacing :smiley:
How long you had them in? They any good?
« Reply #5 on: 24 January 2013, 13:57 »
« Last Edit: 24 January 2013, 16:55 by damien010685 »
Offline navmk4gti
« Reply #6 on: 24 January 2013, 15:35 »
Nice one bud. That is a damn good price for them too.  :smiley:
Offline MattyV6
  • Mk4 .:R32 - The Black Destroyer
« Reply #7 on: 25 January 2013, 09:46 »
The only main issue with fitting an R32 setup is the price of genuine 334mm front discs, its best part of £200 per disc for oem. I've tried cheap Ebay discs before and they just aren't up to the job, under hard breaking they seem to generate so much heat that they warp slightly and you get that 'wobble'.
I've seen complete 2nd hand mk4 R32 front setups for £300 on Ebay. Deffo worth it if you don't mind spending the money, they are powerful stoppers  :smiley:
Not in any way standard :) Dyno Dynamics RR - 280bhp
Offline Glenryck
« Reply #8 on: 25 January 2013, 22:57 »
Yea I've been looking for some second hand r32 or leon cupra r sets I will keep looking the car is going to have the brakes bleed next week and then on to the rollers in the mot bay to test them. Cheers guys.
