Author Topic: Mercedes wheel help.  (Read 1761 times)
Offline fogster
« on: 23 January 2013, 13:38 »
Had the offer of some Mercedes 8 hole wheels, I know I need adapters just wondering if I have to use the mercedes wheel bolts?
Probably a simple yes but wanna make sure.
They are 8x16 et 34.
Re: Mercedes wheel help.
« Reply #1 on: 23 January 2013, 13:44 »
The offset is a little low to run adaptors.
Offline tweed
« Reply #2 on: 23 January 2013, 17:35 »
Yes you need the merc wheel bolts
Yeah it kind of is low, but what's the minimum size adaptors you can get? If its 15mm then you will be fine with 195/40/16 tyres and arch rolled.
Offline tshirt2k
  • Been there...Done that...
« Reply #3 on: 23 January 2013, 19:46 »
The rear will be fine. Fronts will be close but both will need rolled arches.
Mk3 ABF 16VT Megasquirt V3
Offline Callum_K
« Reply #4 on: 24 January 2013, 11:40 »
I'm running 8x16 ET25 with 15mm spacers so ET10, rolled front arches and maxed out on stock camber and I have plenty of clearance with 195/45/16 tyres.  :smiley:
Offline tweed
« Reply #5 on: 24 January 2013, 13:19 »
Really? How low are you?
My tyres rubbed near full lock with 195/45/16 tyres and I'm 8" et20 with full camber. Changing to 195/40/16 gave me loads of room
Offline Gash
« Reply #6 on: 24 January 2013, 15:13 »
et34 lows? please wayne -34 ;) hahah
Offline tweed
« Reply #7 on: 24 January 2013, 16:32 »
You've had to extend your arches and your bumper, now need a respray just to fit your wheels  :laugh:
