Author Topic: Red pipe seals  (Read 3199 times)
Offline EsSeX dAn
Red pipe seals
« on: 22 January 2013, 19:28 »
hi all, with the red pipe from the turbo to pancake pipe, is it possible to replace the green seal that slots into the turbo? i believe mine is leaking. where would i go to get it? thanks
i think i love you.....
Offline Hoggy
  • Mk4 GT TDI 150.
Re: Red pipe seals
« Reply #1 on: 22 January 2013, 19:37 »
I would go to either T.P.S or the dealers.. :)
Offline Steve_PD
Re: Red pipe seals
« Reply #2 on: 22 January 2013, 19:59 »
Yes, you can just buy the o rings. Think they where 75p-£1 when I bought a load. Just go to a stealers.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: Red pipe seals
« Reply #3 on: 22 January 2013, 22:16 »
Seal for red turbo pipe, 2 required - 3C0145117 - £3.67 + VAT
Clips for red turbo boost pipe, 2 required - 1J0145769 - £1.11 + VAT
*These apply to PD130/150, reply with engine code if you'd like confirmation.
I would recommend inspecting the lugs on the pipe and pref replace the clip as well as the seal. VW revised the seals and the new type are green over the original black ones, the clips also changed they had a more rounded profile to the edges, those are now squared so pipe is less likely to pop off as before.
Hope that helps.
Offline EsSeX dAn
Re: Red pipe seals
« Reply #4 on: 23 January 2013, 23:16 »
thank you all for that. much appreciated, especaillt golf gt tdi for the part numbers. ill be visiting my friendly local sealer then!
