Author Topic: best forum to get help with a 1.4 aex engine  (Read 2179 times)
Offline dubpirate
« on: 22 January 2013, 18:20 »
ye
you guys are awesome helping with the rest of the car
but I need to speak to someone who knows this engine
cheers
Offline murraymint
Re: best forum to get help with a 1.4 aex engine
« Reply #1 on: 22 January 2013, 18:25 »
Try here
http://mk3golfowners.co.uk
It's a forum for all mk3 owners not just mainly gti's
josh
Offline dubpirate
« Reply #2 on: 22 January 2013, 18:32 »
is this new seems there isn't much on it
Offline murraymint
« Reply #3 on: 22 January 2013, 19:27 »
Yh only started last year but growin fast
josh
Offline itavaltalainen
« Reply #4 on: 22 January 2013, 20:56 »
Golf mk3 section here is massive:
http://www.motor-talk.de/forum/vw-golf-3-b146.html
wouldn't be the first to post google translate stuff there...
Offline spudboy6
  • Just like a golf ......
« Reply #5 on: 22 January 2013, 20:56 »
What do you want to know about it ?
Offline dubpirate
« Reply #6 on: 22 January 2013, 21:47 »
about the spi carb set up  and my ongoing running issues
sh!te mpg probs 20mpg
no power I have had a 1.4 one of these before this one is not right
only starts if I floor throttle same time
if I blip the throttle a few times it will die
once started and still cold sometimes it wont rev up you have to floor it and wait
Offline spudboy6
« Reply #7 on: 22 January 2013, 23:47 »
What have you tried already ? I'm not sure how old yours is but if its around 96 it will have an obd socket in the dash and it may want the throttle butterfly cleaning with some carb cleaner and then recalibrating ,
Offline Bellend
« Reply #8 on: 23 January 2013, 00:12 »
Check the rubber flange on the throttle body for cracks etc
Where all my moneys went.
Offline dubpirate
« Reply #9 on: 23 January 2013, 21:56 »
rubber flange fine , no fault codes , carb cleaner , tried it all
only thing I touched that made a difference is a vac line going from the carb to a valve on osf wing this is sucking shut and flat the valve is clicking a lot it seems then to go to the charcoal filter
