Author Topic: Advice  (Read 1110 times)
Offline Ninja
  • 19 smiles per gallon
Offline Seanl
Re: Advice
« Reply #1 on: 22 January 2013, 17:59 »
You'll be disappointed with the performance on the standard 9a tbh. Look out for duff sunroof as its a common problem for the runners to go, so it will only tilt and not slide. Passat Moonroof will fit, but looks a little odd. Heater only working on setting 4 - new switches will cost around £100 for a used set!.  temp of heaters - duff heater fan, and no evidence of heater matrix failing as its an absolute ball ache to change!!!!!
http://wiki.the-corrado.net/the_corrado_buying_guide_checklist.html
Offline Ninja
Re: Advice
« Reply #2 on: 22 January 2013, 22:34 »
Thanks pal
Offline Seanl
Re: Advice
« Reply #3 on: 23 January 2013, 07:23 »
Oh and for that price for a valver, you should be expecting a minter.
