Author Topic: Help please  (Read 3884 times)
Offline stevends
Re: Help please
« Reply #30 on: 23 January 2013, 10:44 »
MK4 Golf 1.8 20V turbo, piper cross induction kit with heat shield, forge 007P dump valve, coilover and a remap !
Offline Nino
Re: Help please
« Reply #31 on: 23 January 2013, 10:58 »
That's the Pcv pipe I upgraded mine to a silicone one for £18.99 well worth the price if that is leaking your car won't boost correctly. What was the pipe he removed also have you upgraded the spring in your forge dv?
Btw buy this pipe as a replacement for your broken one. (Just to note that is for an AUM engine)
http://www.creationsmotorsport.com/product-detail.php?pid=25
Current - MK6 GTi Edition 35
Offline stevends
Re: Help please
« Reply #32 on: 23 January 2013, 11:09 »
the pipe he took of was coming from the n75 valve and went to the back of the turbo, think its called waste gate? my engine AGU. the forge is new and what site did u get the PCV pipe from ?
Offline Nino
Re: Help please
« Reply #33 on: 23 January 2013, 11:27 »
Don't know much about the whole n75 stuff (need to look into it) but follow the link below and you can order your replacement PCV pipe for your AGU £18.99 delivered to your door :)
http://www.creationsmotorsport.com/product-detail.php?pid=48
Offline stevends
Re: Help please
« Reply #34 on: 23 January 2013, 11:34 »
happy days thank you for your help.
Offline Nino
Re: Help please
« Reply #35 on: 23 January 2013, 11:43 »
Np pal
Offline Dalo Harkin
Re: Help please
« Reply #36 on: 23 January 2013, 13:32 »
as the others have said, they should have given the car a full check over before mapping the car, most tuning places know the common areas to check for boost leaks and such and then do a run, and from there diagnose any faults, run vagcom etc.
'most' tuners do offer a try before you buy type service where if you are not happy with the map, they take it off or dont charge you, so make sure you 'kindly' let them know that as far as you are concerned you have paid for a service that hasnt done what it is meant to
Offline Nino
Re: Help please
« Reply #37 on: 23 January 2013, 18:09 »
Has he given you a refund?
Offline stevends
Re: Help please
« Reply #38 on: 25 January 2013, 16:48 »
Some info, done what you all said IE checked all boost hose and vacuum hose. Found one pipe that I replaced. Took the car back up to the boys who were very understanding. Ryan sent some time gettin the car sorted. Some tweaks here and there and it's going like sh!t of a blanket.
