Author Topic: Help please  (Read 3883 times)
Offline barrym381
Re: Help please
« Reply #10 on: 22 January 2013, 21:34 »
dont take it near the guy again  :grin: get it to some1 that knows what they are doing
Offline stevends
Re: Help please
« Reply #11 on: 22 January 2013, 22:01 »
Yea i no. Id like to no why its not boosting properly
MK4 Golf 1.8 20V turbo, piper cross induction kit with heat shield, forge 007P dump valve, coilover and a remap !
Offline barrym381
Re: Help please
« Reply #12 on: 22 January 2013, 22:14 »
he should be tellin you that  :smiley:
Offline stevends
Re: Help please
« Reply #13 on: 22 January 2013, 22:27 »
He said id need 2 leave it in with them.
Offline barrym381
Re: Help please
« Reply #14 on: 22 January 2013, 22:29 »
by the sounds of things a wouldnt leave a push bike with this guy to fix  :grin: never mind mappin my car
Offline rio_gti
Re: Help please
« Reply #15 on: 22 January 2013, 22:45 »
Check all your boost pipes, vacuum pipes etc and also try and find someone that has vagcom and get it scanned!!!
Offline stevends
Re: Help please
« Reply #16 on: 22 January 2013, 23:39 »
 :smiley: id been better let my 5yr old look at it
Offline stevends
Re: Help please
« Reply #17 on: 22 January 2013, 23:42 »
is there a diagram on the internet that i could check, to be honest i havnt a clue about VW engines or were all the boost pipes, vacuum pipes etc are.
Offline Nino
Re: Help please
« Reply #18 on: 23 January 2013, 00:01 »
You can do a lot of checks yourself.
* diverted valve:
Its a small black valve that located near the top right hand corner of you engine bay just next to your air filter box. It kind of looks like a small round tube with 3 tubes leading off it. One on the the top (very small) one at the bottom and one on the side (both of these are the same size) it will take you about 3-6 mins to remove it and all you need is a driver to undo the screws on the clips holding it in place.
Once you have removed it you will notice that if you put your finger in the bottom you can push up the piston (it should be hard) now what you want to do is push it up then before your remove your finger cover the nipple tube on the top then remove your finger from the bottom. If done correctly you will notice that the piston you pushed up will stay up (note that its normal if it moves a tiny bit). If however after creating a vacuume the piston just drops straight back down then yes your diverter valve is broken. But if it stays up its fine. Also worth noticing if you spot small amount of oil in and around the valve, don't panic, that's normal.
However when remapping a golf you should never really use a stock DV you should always upgrade to a forge 007p or forge 008 and always ensure you use a recruitalting DV and NEVER a "dump valve"
Hope this helps
Current - MK6 GTi Edition 35
Offline stevends
Re: Help please
« Reply #19 on: 23 January 2013, 00:35 »
* diverted valve:
Hope this helps
ive a pipercross induction filter on and a forge 007p. i changed the n75 valve cause he took some hose of from the turbo and it boosted fine then he put the pipe on and my boost will not go past 0.3 bar and standard is about 0.6 bar. my car has been remapped and now should be running up to 1 bar boost.. to be honest im just going by what i seen. sorry if its not enuf info
