Author Topic: engine swop  (Read 2105 times)
Offline greendragon
engine swop
« on: 21 January 2013, 22:59 »
i wana put my mk3 gti 8v engine into my mk1 but what i need to no is what things do i need to change or adapt
thanks
Offline danny_p
Re: engine swop
« Reply #1 on: 21 January 2013, 23:25 »
it sits to high so need to ether adjust the mounts or find a bubbel block 2ltr found in some audis code is 3A
if going to the bother of getting a tall block to fit why not find a 16v  :evil:
all the VW's have gone bar 1.
Offline greendragon
Re: engine swop
« Reply #2 on: 22 January 2013, 00:03 »
ive got the donor car so might aswell chuck it in
mounts arnt a problem do i need to change the manifolds?
thanks
Offline greendragon
Re: engine swop
« Reply #3 on: 24 January 2013, 23:03 »
can anyone else help?
Offline danny_p
Re: engine swop
« Reply #4 on: 25 January 2013, 00:25 »
mk3 lump will usualy foul bonnet on a mk1 unless its  droped a bit , never used the mk3 inlet in a mk1 always swaped the head and used mk1 manifolds
Offline greendragon
Re: engine swop
« Reply #5 on: 25 January 2013, 00:41 »
what head and manifolds did you use?
and did you have to adapt them to fit thanks
Offline danny_p
Re: engine swop
« Reply #6 on: 25 January 2013, 19:39 »
mk1 manifolds usally a mk2 head ( for hydralic tappets ) if useing a bubbel block or mk3 bottom end when just doing a 1.8 - 2.0 conversion
or if doing a non gti mk1 to 2.0  tend to use what bits are avalible at the time or are withing budget  usally mk1 manifolds tho on ether mk1 or mk2 head
Offline greendragon
Re: engine swop
« Reply #7 on: 31 January 2013, 21:02 »
Does It have to be a 8v head as my block is a 8v
