Author Topic: oil leak help  (Read 1848 times)
Offline col-mk3
oil leak help
« on: 21 January 2013, 19:46 »
got a leak from bit were all bolt's go on the pic
my mechnic friend said it some sort seal could any 1 help with part id need to stop the leak thanks?
its 2litre 8v
Offline sharki786
  • GOT BOOST??
Re: oil leak help
« Reply #1 on: 21 January 2013, 20:56 »
Cant seem to see the leak. If you circle it then there would be a chance someone could help you out
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline gazpowells
Re: oil leak help
« Reply #2 on: 21 January 2013, 21:49 »
As above, cant seem to see anything in that pic
Offline col-mk3
Re: oil leak help
« Reply #3 on: 22 January 2013, 11:28 »
it's likeleft side rubber driveshaft were 5 bolts are and then other side of the silver shiny bit
Offline Malz0r
  • Haters gunna hate.
Re: oil leak help
« Reply #4 on: 22 January 2013, 14:48 »
Sounds like you mean the seal on the box has gone where te shafts go in! Can't remember the part number tho
Offline tweed
Re: oil leak help
« Reply #5 on: 22 January 2013, 18:00 »
On the drive shaft? Cv joint?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: oil leak help
« Reply #6 on: 22 January 2013, 18:03 »
THIS
fooked Cv boot
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline sharki786
  • GOT BOOST??
Re: oil leak help
« Reply #7 on: 22 January 2013, 18:48 »
Could also be the gearbox cup seal thats gone.
*****MK4 GTI T*****
Offline col-mk3
Re: oil leak help
« Reply #8 on: 23 January 2013, 00:08 »
that's the one mate anyone know the part number?
Offline col-mk3
Re: oil leak help
« Reply #9 on: 25 January 2013, 12:08 »
bump
