Golf mk3
hardmonkeys
Screechy belt?
Topic: Screechy belt? (Read 986 times)
madsb
GTI forum regular
Screechy belt?
21 January 2013, 18:54 »
One of the belts in my car's engine makes a loud screeching noise sometimes when starting the car. I believe its the one kind of next to the air intake box. Is that the one charging the battery? Any tips or howtos for tightening it?
cheers
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Screechy belt?
21 January 2013, 19:09 »
just get it changed..... both together cost <20£......
if you get a haynes then you're at 30£.... and you need an adjustable spanner for 5£
tightening will help only for about 2 days and you'd still need the spanner.
madsb
GTI forum regular
Re: Screechy belt?
21 January 2013, 20:10 »
just bought the car, but pretty sure the belt has just been changed..
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Re: Screechy belt?
21 January 2013, 20:34 »
Were both changed, if so check the tension. Theres a toothed bolt to do this under the power steering pump.
Last Edit: 21 January 2013, 20:36 by thai-wronghorse
Golf mk3
hardmonkeys
Screechy belt?
