Author Topic: VR6 pedal box / SEAT clutch cable  (Read 1277 times)
Offline Malz0r
  • Haters gunna hate.
« on: 21 January 2013, 16:53 »
Sorry to be a pain but I cant seem to work out the right part!
I'm doing a VR6 conversion into a GTi 8v and in all set other than I don't want to change the pedal box so I'm going for the SEAT Ibiza method and I literally just need to know part number/ what age will be okay so I can pop down my local scrappy and grab one!
I did do loads of search's but seem to be blind to the actual answer!
Thanks all.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: VR6 pedal box / SEAT clutch cable
« Reply #1 on: 21 January 2013, 17:16 »
EH ?
you dont need to do anything with your pedal box to fit a VR6 engine.. its the same pedal box
unless your car is a 93 or older
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Malz0r
« Reply #2 on: 21 January 2013, 17:18 »
Really? It's a 1995 mk3 GTi 8v AGG, I need to go hydro clutch?
Offline F17BAD
« Reply #3 on: 21 January 2013, 17:25 »
the hydro bits all fit to the GTI pedal box, the GTI/VR6 pedal box is the same
you need the hydro bits off a 16v or a VR
Offline Malz0r
« Reply #4 on: 21 January 2013, 17:27 »
Ahhhhh okay! Thanks that's a huge help will grab one tomorrow from the breakers!
I was reading a post on here from years ago and they were banging on about the pedal
Box proly due to it not being a GTi I would guess!
Anyway thanks!
Offline F17BAD
« Reply #5 on: 21 January 2013, 18:07 »
only very early cars need pedal box from a later car (like mine did)
you just need all the hydro bits, the pipes that go from brake resovour to secondary cylinder and then theirs  a cylinder that sits on the gearbox, you might already have this on your VR6 box?
uplad a pic looking down at the top of it and i can tell u
