Author Topic: car wont start even with jack plugs.  (Read 3020 times)
Offline search
« on: 21 January 2013, 15:13 »
car started ok yesturday, then today its as if the battery is just on the way out at first sounded like it was going to turn over, then just got worse and worse untill it sounded like it couldnt be bothered anymore.
tried to jack start it but still nothing how ever it does sound a little bit better engine wise but still no turn over. do you think a new battery would do the trick or waste of money??
i did spray carb spray in the carburetor yesturday but this couldnt of broke anything could it?
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline nightroamer
  • Mk3 16v
Re: car wont start even with jack plugs.
« Reply #1 on: 21 January 2013, 15:30 »
wouldn't think carb cleaner will affect it.
With a jump start does the engine turn over freely? did you jump from another battery or a running car.
Offline search
« Reply #2 on: 21 January 2013, 17:04 »
from a running car and did nothing. what would happen if iv flooded the engine? I'm pretty sure its the battery as when I have head lights on and try turn the car over the head lights just turn off.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline JC
  • Back in the North.
« Reply #3 on: 21 January 2013, 18:45 »
if you had a running car attached and still nowt it wasnt connected correctly.  :whistle:
or
starter motors completely fubared  :laugh:
Offline search
« Reply #4 on: 21 January 2013, 21:43 »
or
FFS you might be right i was connecting the negative to my battery aswell not to a metal bit on my car..... could this be where the problem was.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline danny_p
« Reply #5 on: 21 January 2013, 23:29 »
probaly find the jump leads were crap, leave the cars connected together for a fw mins  so your battery can gain some charge if its not completly fubared it should go.
had to make meyself a pair of jump leads as i need them quite a lot work wise and kept on melting shop bought ones
all the VW's have gone bar 1.
Offline antogoof
  • bbm mk2 g60
« Reply #6 on: 22 January 2013, 10:46 »
make sure the battery has charge in it then get a mate to give the starter a few taps as you try starting it, if i just ticks is fecked, i get one from a scrapper for your car, i just took one off an abf to fit on a g60 and ive used one off a cl for a gti. or look for somewhere that does exchange. :smiley:
mk2 bright blue met bits wanted in north west.
Offline search
« Reply #7 on: 23 January 2013, 08:31 »
.   thanks were not sure what it was could be fuel filter not sucking or automatic choke. fingers cross it starts ok today.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 24 January 2013, 22:39 »
Have you tried to bump start it?
