Author Topic: Will this cheapy cambelt kit do?  (Read 2499 times)
Offline Leroy
  • Golf GTI Anniversary 16v
« on: 21 January 2013, 09:31 »
Trying to save a few quid on the boring stuff so i can spend more on the more exciting things like coilovers. Will this cheap ebay kit be ok or are you best buying genuine with things like cambelts?
Cambelt and tensioner kit
http://www.ebay.co.uk/itm/Volkswagen-Golf-2-0-Gti-16v-Cam-Belt-Kit-Aug-1991-Sep-1997-/260852394752?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cbc03ab00
Re: Will this cheapy cambelt kit do?
« Reply #1 on: 21 January 2013, 09:58 »
A gates kit will be ok, they are good quality :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 21 January 2013, 10:35 »
Gates and INA are good makes. Never go cheap on your cambelt!!!
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline tweed
« Reply #3 on: 21 January 2013, 10:36 »
Things not to save money on are...
1.cam belt kit
2.any engine component
3.tyres
« Reply #4 on: 21 January 2013, 10:46 »
1.cam belt kit
3.tyres
Agreed however gates make a lot of oe stuff so they are fine to use.
Offline itavaltalainen
« Reply #5 on: 21 January 2013, 12:05 »
I have used a "cheap" gates kit off ebay.... nothing to worry if belt comes from gates, conti or dayco.
tensioner, e.g. INA, SKF,.....
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 21 January 2013, 12:08 »
As above,  i generally use Dayco cambelts and Gates power steering and aux belts.
Offline Foreveryoungaus16v
« Reply #7 on: 21 January 2013, 12:33 »
No point spending money on fancy stuff until car is running correctly
163 BHP (TSR POWER RUN)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #8 on: 21 January 2013, 12:34 »
continental cambelts FTW :smiley:
Got a genuine audi one on at mo but used the conti ones on all other engines we done
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Leroy
« Reply #9 on: 21 January 2013, 13:06 »
Good point well made, im making sure im spending my tight budget where it should be spent.
Thanks all for the advice!
