Author Topic: Are these any good for my mk4?  (Read 2123 times)
Offline Scott-R
  • GoT BoosT!
Golf GTI ... What else would you have?
Offline dom
  • Back in a Mk4
Re: Are these any good for my mk4?
« Reply #1 on: 20 January 2013, 20:02 »
Are these a good offset for my car it's not too low!
http://www.alloywheelcashandcarry.co.uk/vw-alloy-wheels/vw-golf-mk4/bbs-ch-style-18-inch-h-pcd-5x100-et-35-cb-57.1-hyper-silver-polish-lip
Yeah ET35 is a decent enough offset, you may need a 5mm spacer on the front to prevent the tyre from scrubbing on the strut though.
« Reply #2 on: 20 January 2013, 21:32 »
Will be fine, just be carefull with the quality of some reps however.
Offline dom
  • Back in a Mk4
« Reply #3 on: 20 January 2013, 21:37 »
I know that some reps can be hit & miss, the CH's on mine are excellent quality though
Offline Scott-R
  • GoT BoosT!
« Reply #4 on: 20 January 2013, 21:48 »
Mite sound crazy but is there any change that spacers could ruin my wheel bearings?
« Reply #5 on: 20 January 2013, 21:52 »
5mm or 10mm will not hurt the bearings that much.
Offline Scott-R
  • GoT BoosT!
« Reply #6 on: 20 January 2013, 22:02 »
that much? so is that a yes?
Is it better to get more offset and have no spacer and does anyone know of a wheel with more? or have some wheels on with spacers and do you find wheel bearings going alot?
Offline dom
  • Back in a Mk4
« Reply #7 on: 20 January 2013, 22:08 »
A lower offset would bring the wheel away from the strut, however loads of people run spacers without issues. I'm running 15mm up front and 20mm on the rear and haven't had any issues.
Offline Rob Zombie
« Reply #8 on: 21 January 2013, 16:58 »
Dom - what CH reps do you have there?
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline dom
  • Back in a Mk4
« Reply #9 on: 21 January 2013, 17:00 »
No idea, I got them from Baxxy - you could try dropping him a PM :wink:
