Author Topic: Misfire/erratic idle with video, update please read  (Read 4070 times)
Offline Chris#101
« on: 19 January 2013, 19:23 »
Hi all just gone to start my car and it has an erratic idle / misfire. Ive taken it for a quick spin and on very light throttle the car is bucking yet the throttle is kept in the same position. How ever under hard acceleration it seems to drive fairly smooth. Considering this has been r-tech'd Nd running 232bhp +258lbs ft+ it seems fairly flat to normal.
I've. Cleaned out the maf, checked coil packs are fully pressed down/ connected anything else I should check?
Coil packs were replaced under warranty within a year ago because of the recall.
I have fault codes 17511 & 16514 lambda related.
Here's a video
http://m.youtube.com/watch?v=N7FkA1YAZy8&feature=plpp
Please help
« Last Edit: 21 January 2013, 17:09 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris#101
Re: Help with warning light and fault codes.
« Reply #1 on: 19 January 2013, 19:23 »
« Last Edit: 20 January 2013, 13:04 by Chris#101 »
Offline Chris#101
Re: Misfire/erratic idle with video, please help
« Reply #2 on: 20 January 2013, 13:10 »
Thought I'd recycle my old  thread with a new problem  :rolleyes:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 20 January 2013, 16:40 »
If those faults are lambda related it could be throwing your fuelling about all over the place. Can you get some lambda logs?
Offline Chris#101
« Reply #4 on: 20 January 2013, 16:52 »
Had the lambda codes for a few weeks now which I've been meaning to get round to sorting, dunno whether these new symptoms are related or not.
The roads round here are deadly ATM and traction control is kicking In every few seconds literally, so I've unplugged both plugs on the throttle body as I've had a similar problem before. Plugged them back in and the erratic idle has pretty much gone away but it's incredibly flat to drive :undecided:?
Unable to take any logs unfortunately
Offline Chris#101
« Reply #5 on: 21 January 2013, 17:09 »
Right Ive just unplugged the maf and it seems to have a nice steady idle and no boggyness to it. Is it safe to go for a quick blast with maf unplugged to see if it has gotten rid of misfire?
Also just thinking out loud, IF the maf is fubaredd could that be throwing the fueling out, bringing up error codes 17511 & 16514 lambda related or the other way round?
thanks in advance
Offline Chris#101
« Reply #6 on: 21 January 2013, 20:03 »
thanks in advance
Does a knackered maf throw up codes?
Offline rio_gti
Re: Misfire/erratic idle with video, update please read
« Reply #7 on: 21 January 2013, 20:22 »
Bad maf doesn't always throw up a code, apparently it's not wise to drive with it unplugged but if it was mine I would  :lipsrsealed:
If it could be that buggared try givin it a clean with maf cleaner (or carb cleaner but a tiny ammount!!!)
Offline pickles
  • Next!!!
« Reply #8 on: 22 January 2013, 09:18 »
what engine code. iv a AGU and i was getting similar symptoms, i ended up changing the n75 which helped a bit but problems stopped when i changed MAF, think my CAI is a MAF Killer lol
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Dalo Harkin
« Reply #9 on: 22 January 2013, 12:24 »
ran mine with it unplugged for a long time, I know its not advisable, but only because it runs on default values.
