Author Topic: out with the new in with the old. (mk3-mk2)  (Read 2980 times)
Offline search
« on: 19 January 2013, 18:38 »
Yup just got a little mk2 today swapped my mk3 for her so expect lots questions LOL.
two main things i need to fix up is
leak in the sun roof and footwell.
Car only tunrs over when foot down on acceleator.
anyways thats me, see you all around.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline X4MGS
  • VAG Parts SNOB!!!
Re: out with the new in with the old. (mk3-mk2)
« Reply #1 on: 19 January 2013, 19:02 »
Cool....
What model/year did you get?
Any Pictures.
For More Info Click To See;
Offline search
« Reply #2 on: 19 January 2013, 19:16 »
just a 1.3 4+e but then my mk3 was just a 1.4
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline theclash
« Reply #3 on: 19 January 2013, 19:47 »
You better with the mk2 than the mk3 for one it will last longer
Plenty of answers via the search button
« Last Edit: 19 January 2013, 20:48 by theclash »
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 19 January 2013, 20:38 »
What you got planned??
IMO dump the grille... 1st...
Offline search
« Reply #5 on: 19 January 2013, 22:18 »
first things first! fix a few faults then nothing OTT... might change the front end to round lights. just looking in to it all at the moment.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline antogoof
  • bbm mk2 g60
« Reply #6 on: 20 January 2013, 19:10 »
do it! its a piece o piss to do, dunno if you need a different slam panel but its easy to change, and someone will buy the jetta front.
check your doorcards are not rotten at the bottoms, pull em off and inspect the membrane on the door.
this needs to be pretty much watertight mk2 s are designed to let water in the doors. also make sure the drainholes are clear at the very bottom of the doors so the water can drain away.
check the door shut seals are in good nick too and the roof gutters as this can also be a problem.
alsso the drainholes from the sunroof can fill with crap and you need something like a wire coat hanger to clean them.
other than that it could be windscreen seal? heater box? the panel under the bonnet where the wiper mech is?
dont worry tho, most mk2 owners have these problems, including me! :smiley:
mk2 bright blue met bits wanted in north west.
Offline search
« Reply #7 on: 20 January 2013, 19:58 »
yeah been on google got some hints n tips, will inspec door cards asap....
do u ever use ur Sun roof? iv never had use for one before just open my window lol. so thinking along them lines if I can't find the leak ill just silicone it up lol.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline antogoof
  • bbm mk2 g60
« Reply #8 on: 20 January 2013, 23:29 »
only in the summer but id think twice befor silicone, if the drainholes are working it should be reasonably ok.
rule out everything else first, membranes are cheap fitting them is cheap and the heater box and scuttle would only need sealent if they are leaking. clean the sunroof drainholes first too, and check all these areas first. a sunroof seal is only about 30 notes if it comes to that :smiley:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 21 January 2013, 00:21 »
No Brainer To Me...
You now own a classic car.. Treat it as such...
There are only 2 places a sunroof can leak from...
1, the 4 drain holes
2, the rear drainage panel attached to the rear of the sunroof panel (can only be found once removed)...
As suggested look at more OBVIOUS culprates 1st...
See this thread...http://www.golfgtiforum.co.uk/index.php?topic=247266.0
