Author Topic: MK4 GTI Front Wipers stopped working.  (Read 1735 times)
Offline dlh
« on: 19 January 2013, 08:04 »
Hi everyone.
It has been cold the last few days, I drove to the train station yesterday morning and the wipers were working fine.
Last night i sat in my car and ran the heaters until the windscreen was clear but when i tried the front wipers i get nothing?
I tried the Fuse this morning and this is all good , When I pull the lever I get no water shooting either and when I put the front wipers on I get no sound and no movement at all.
The Back is working fine.
Anyone ever had this before Is it a common failure?
help please im new to this
D
Offline Mr_Orange
Re: MK4 GTI Front Wipers stopped working.
« Reply #1 on: 19 January 2013, 09:10 »
The linkage can often seize up. Strange though that the jets didn't go off, unless it only squirts when the wipers run. Do a search for wiper linkage seized yo  :wink:
Build thread clicky
Offline gazza1971
« Reply #2 on: 19 January 2013, 13:47 »
Spay the linkage with WD40 through the bulk head i did mine when they was very slow mines been perfect since just keep them sprayed up .
Golf Gti 20v Turbo AUM
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #3 on: 19 January 2013, 14:20 »
Control unit can give trouble  :wink: It looks like this...
Offline james2
  • No scammers please.
« Reply #4 on: 19 January 2013, 14:23 »
i did this to mine as well but they finally went when i was 96 miles from my house in heavy rain ,i had to drive home on the motor way. Replace the linkage  :evil:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline dlh
« Reply #5 on: 19 January 2013, 21:21 »
Thanks everyone so it has evolved since this morning.
I now can hear the motor buzzing when i stand outside with the bonnet up and hear the speed adjust when i hit the lever so it looks like the motor is good so can we say it must be 100% the linkage.
The jets are now spraying the windscreen so looks like they were just frozen.
So with this extra information i can confidently say it is linkage I will order a new one , will try WD40 until the part arrives and pray it does not rain.
Offline james2
« Reply #6 on: 19 January 2013, 22:51 »
yeah its a common fault, remove the linkage and try turning each wiper, one will be so stiff it will not move. Water gets past the seal on the spline of one of the wipers ,passanger side if i remember. Also new linkage don't come with a new seal.  :evil:
