Author Topic: mobilaser problem  (Read 2745 times)
Offline Screech16v
  • MK3 20vt AGU
Re: mobilaser problem
« Reply #10 on: 18 January 2013, 20:42 »
There are companies that can replace your fob such as this ,but im not sure if it has to be working for them to reprogramme a new one
http://www.remoteskeyrepairs.co.uk/replacementkeyfobs/keyrepairsandreplacementfobsgt_auto.phpn
I would try a new battery first.
Offline bailey281992
« Reply #11 on: 18 January 2013, 20:47 »
I think I might try the battery and then if that doesn't work then ill try a new fob.
Thank you.
Offline tweed
« Reply #12 on: 18 January 2013, 21:42 »
I would try swap the button after the battery.
« Reply #13 on: 19 January 2013, 12:29 »
Just put a new battery in the fob, and it seems to be working a lot better now then the old battery.
Thanks a lot for your help :)
Offline joshstanvw
« Reply #14 on: 25 January 2013, 14:40 »
what i did in this situation is waited to get stuck at side of the road then called the RAC out they bypassed the immobiliser for the grand charge of £0 might be worth a try when it plays up bad
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
