Author Topic: mobilaser problem  (Read 2744 times)
Offline bailey281992
mobilaser problem
« on: 18 January 2013, 18:57 »
Basically my car only starts when you enter the key, turn it and then press the mobilaser button and the red light flashes and you turn the key again and the car then starts. The button is also to lock and unlock the car.
The button has been working for 16years and now it has started to play up, there is a garage that i am going to take to, but i have heard they charge £50 an hour which i dont mind if they only need to change the battery in the mobilaser.
Could anyone give any help, or suggest?
Thank you.
Offline tweed
Re: mobilaser problem
« Reply #1 on: 18 January 2013, 19:04 »
in the fob you mean?
take it apart, comes in two halfs then take the battery to Sainsbury  and find the same and replace it.
my local Sainsbury has over 100 different types so should imaging they're all the same.
« Reply #2 on: 18 January 2013, 19:08 »
yeaaa the fob, i got told that you only had 30seconds to change it and then it will lose it memory?
is that right?
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 18 January 2013, 19:36 »
Best be quick then  :grin: who told you that? the garage by any chance?
« Reply #4 on: 18 January 2013, 19:41 »
No lol, a friend. Is that wrong then?
« Reply #5 on: 18 January 2013, 19:45 »
The thing is, their night be a chance that it is not the battery in the fob, it might be the actually button?
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 18 January 2013, 20:02 »
I had the same problem not so long ago,only one fob and when that failed that was that ,now I have to use the key thing in the dash.
Offline tweed
« Reply #7 on: 18 January 2013, 20:04 »
Battery thing is not true!
If its the button get a fob from eBay then swap the button over.
« Last Edit: 18 January 2013, 21:41 by tweed »
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 18 January 2013, 20:21 »
He probably means the button that will be soldered to the pcb inside the case.
« Reply #9 on: 18 January 2013, 20:28 »
So a new fob would be better than getting the battery changed in the fob?
