Author Topic: What a day or do I mean a week UPDATE UPDATE UPDATE  (Read 3303 times)
Offline theclash
« on: 17 January 2013, 20:50 »
Last week I stripped out all front carpets and sound deadening after finding water in passenger footwell
Door membrane good, matrix good, blower seal good, scuttle clear, door seals good,sunroof rubber pipe good and clear
So a week later while sat outside on ramps while I replace sump gasket I look in passenger footwell and water  :sad: but no traces of where it as run in from. I was lay in bed last night and convinced myself it was the front sunroof drain tubes the inch metal pipe behind the headlining that must have rotted and leaking water and it's finding it's way through trim and onto the floor. So today out came the headlining and low and behold....no rot or leak  :embarrassed: next step is windscreen out resealed and put back although there is no evidence of wet under the glovebox but it's the only thing left to check. I've currently no headlining no passenger or rear seats carpets or centre consol in the car it looks a sorry state but sooner I find this leak the better
God knows what my neighbours think of me usual passing comment is " messing with that car again "
« Last Edit: 19 January 2013, 19:44 by theclash »
Offline X4MGS
  • VAG Parts SNOB!!!
Re: What a day or do I mean a week
« Reply #1 on: 17 January 2013, 21:12 »
Have you checked the rear lights? and or tailgate & seal?
One MK2 I had let water in under the rear light cluster...
Problem with water is it will lye in the lowest point but that don't mean it is coming from that area....
Other options could be the seals in the bulk head but these seems unlikely!
Checked blower motor cover & seal??
For More Info Click To See;
Offline clipperjay
« Reply #2 on: 17 January 2013, 21:19 »
The rubber gromit that holds the bonnet cable?  :wink:
Offline theclash
« Reply #3 on: 17 January 2013, 21:40 »
Rear off car is nice and dry
I replaced and sealed bonnet cable grommet when I first got the car (4 years ago) with genuine vag that was leaking in drivers footwell
Hopefully with headlining and seats door cards carpet out I will be able to trace it time will tell but hopefully not to long though cause it looks like a proper shed inside
Offline CanisLupus
« Reply #4 on: 18 January 2013, 01:00 »
Hmm...you've mentioned and checked most places already...my tip may have been on windscreen seal or heater blower opening under bonnet but you have checked that also. Another worthy place of checking is under the ecu. There's only a bonded in metal plate covering the hole there, mine was leaking there too and if your car is on a slant it MAY be running towards passenger side...but kind of unlikely.
When I had a leak and couldn't find the source: Dry everything out again in the footwell, grab some white chalk and just draw a perimeter around the area of the leak...or even colour the whole footwell in. Should show up any water lines and you can go from there.
@X4MGS...sorry for OT, I just saw your name and thought woot? I'm sure I bought a few things off the bay the other day and sellers name was the same. It was actually you haha. Bought the rear dome rubbers and the battery strips. Thanks for the speedy postage, items came straight away!
« Last Edit: 18 January 2013, 01:02 by CanisLupus »
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 18 January 2013, 01:50 »
Yes that would be me & Thanks for the feedback...
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 18 January 2013, 01:52 »
I would go back to the basics... Are you sure the door card membrane aint leaking.... 100%????
Get someone to hold a hose over the car and sit inside and watch for a small leak...
Offline Robw
« Reply #7 on: 18 January 2013, 14:19 »
Sprinkle some flour on the floor and then you should be able to trace where the water is at least coming from. Not too much or it'll be a real mess!
Offline theclash
Re: What a day or do I mean a week UPDATE UPDATE
« Reply #8 on: 19 January 2013, 19:43 »
Firstly a big thanks to everyone for help and suggestions
I have found the source of my leak today I hope this helps anyone in a similar position
I got my mate to hosepipe over various parts of the car, windscreen sunroof etc while I sat in car and waited for the water. It seems the edge of the passenger door although touching the roof gutter seal is letting water in it seems to have lost its firmness and collapsed gone soft.
So my plan is next week is to either adjust the door striker to pull door in more or bend the door frame a little failing that it will need a new roof gutter
Offline X4MGS
  • VAG Parts SNOB!!!
Re: What a day or do I mean a week UPDATE UPDATE UPDATE
« Reply #9 on: 19 January 2013, 20:36 »
At least you found it!!
