Author Topic: 00537 - Lambda (Oxygen Sensor) Regulation: Lower Limit  (Read 1013 times)
Offline ryanbrook
got this code when doing a diagnostics.
I have had a look on ross-tech and found this:
Possible Causes
Activated Charcoal Filter Solenoid Valve 1 (N80) leaking/sticking
Injector faulty (not closing completely)
Fuel Pressure Regulator faulty
Possible Solutions
Check/Replace Activated Charcoal Filter Solenoid Valve 1 (N80)
Check/Replace/Clean Injector(s)
Check Fuel Pressure Regulator
Right i know i could go ahead and change everthing, but just wondering if you guys know what the most likely culprit is?
