Author Topic: 20vt help  (Read 12762 times)
Offline Ess_Three
Re: 20vt help
« Reply #20 on: 18 January 2013, 09:21 »
^^ it was a barometric pressure sensor integrated into the ecu.... so they did have a map sensor, just not one you could see lol
That makes sense.
You need a MAP of some description to modulate boost. The early 1.8Ts still ran the N75 boost control circuit I assume?
They just measured MAP in the ECU, as opposed to a remote sensor in the charge pressure pipework.
..but gaining motorcycles.
Offline Gash
Re: 20vt help
« Reply #21 on: 18 January 2013, 11:25 »
a bam engine with a throttle cable?
im beginning to think that might be an aum (?) with a s3/tt manifold!
Why would you think that? AUM was DBW too.
not a aum, agu i meant! doesnt add up why it has a throttle cable attached
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: 20vt help
« Reply #22 on: 18 January 2013, 12:22 »
That sensor on the inlet is the temp sensor not map
Map sensor goes before TB
Looks like its had a lot of corners cut and alot of TLC
where u located ?
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Ess_Three
Re: 20vt help
« Reply #23 on: 18 January 2013, 13:56 »
Erm...would that be because it's in a Mk3 and running a non-OEM ECU?
I'm guessing that would explain it...it makes the wiring far more simple.
Offline F17BAD
Re: 20vt help
« Reply #24 on: 18 January 2013, 14:24 »
Yea emerald uses cable throttle and no maf and I think no map
And no knock control
I'm not a fan personally
The Engine is deffo the amk/bam you can see the charge pipe on left of engine
The Intercooler size looks ok but the piping looks horrific supirised it's not damaged that engine
Wouldn't go too big either as that's just bad for boost
Look on 600bhp evos at the Intercooler pipe work, it's not that big, about same as mine, stock size is what u need
Folk that go too big are making things worse bit like havin a too big Intercooler
Offline hobbiniho
Re: 20vt help
« Reply #25 on: 18 January 2013, 17:50 »
I wonder if this installation runs a lambda sensor and Cat?
no lambda and no cat  :laugh:
Offline hobbiniho
Re: 20vt help
« Reply #26 on: 18 January 2013, 17:51 »
where u located ?
shetland islands
Offline hobbiniho
Re: 20vt help
« Reply #27 on: 18 January 2013, 17:53 »
100% definitely a BAM as its stamped on the top of the engine
Offline F17BAD
Re: 20vt help
« Reply #28 on: 18 January 2013, 17:57 »
mine runs no Cat either but i do run lambda sensors and all other sensors
i run on the Audi S3 ECU  :cool: but much dofferent set up to you as i have the RS2 Turbo, manifolds and a External wastegate plus fully forged internals
Offline hobbiniho
Re: 20vt help
« Reply #29 on: 18 January 2013, 18:05 »
yeh i went to have a look at you build thread but i think it will take me quite a while to read  :laugh: i was really just interested in how it was all meant to run with half the sensors missing  :grin: but it does run and it goes well for what is a basically standard engine, i was thinking of upgrading the TIP and sorting the intercooler then getting it mapped to run properly on 95ron fuel as we dont get super unleaded here  :angry:
