Author Topic: The blowing is still there after doing this?  (Read 3365 times)
Offline markallen
  • AUM 1.8 20v Turbo 150bhp for now ;)
Re: The blowing is still there after doing this?
« Reply #10 on: 18 January 2013, 13:48 »
Are you sure it's blowing from the joint? and hasn't got either a crack on the downpipe weld or a massive crack on the hot side of the turbo? Or you haven't got flat faces on your joints
If it was either of these why would it sound better with paste around the joint?  :huh:
Golf Mk4 GTi Turbo, R32 front bumper, Lowered on ProSport Coilovers, Bora illuminated vents, Armrest, Heko wind deflectors, Aluminium vinyl trim.
Soon to be added, FMIC, 3" exhaust, Remap..oh and new turbo :(
Offline rio_gti
« Reply #11 on: 18 January 2013, 14:19 »
Also I thought about a crack but in theory when it gets hot shouldn't the metal expand and the blowing get quieter??
Offline Jin_C
« Reply #12 on: 18 January 2013, 14:24 »
Could it be because that it is blowing from two places. When you fix the downpipe joint you can hear the quieter one but before, the downpipe is drowning out the other gap
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline markallen
« Reply #13 on: 18 January 2013, 14:30 »
I guess I can only try and fix the joint first and then see what happens. Will update tomorrow when I've done it.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 18 January 2013, 14:59 »
Like Chris said you definitely shouldn't be using paste for any joint before the cat
Offline markallen
« Reply #15 on: 18 January 2013, 15:06 »
Why though?
Offline stace110
« Reply #16 on: 19 January 2013, 10:36 »
If you use the paste between the two flat surfaces ,The excess on the inside of the downpipe could break off and slightly block/damage the cat .
1999 AGU, sitting on Dotz 18's,forge 008p, r32 side skirts. satin silver....more to come
Offline markallen
« Reply #17 on: 19 January 2013, 10:40 »
If I do and it sorts the blowing I will get a new downpipe without a cat anyway. It's just to try and source the blowing issue it's not going to be a forever job.
Offline golfyste
  • Project track car
« Reply #18 on: 19 January 2013, 18:14 »
Just change it all!
Uprated turbo and exhaust ..... Sorted  :grin:
Offline markallen
« Reply #19 on: 20 January 2013, 00:15 »
Just change it all!
I would but your shying away from fitting it all ;) ha ha
