Author Topic: Golfyste's road legal mk4 "project track car"  (Read 280472 times)
Offline golfyste
  • Project track car
Managed to get the front feet welded up now i just need to grind the bottoms flat so they sit flush again and then get them fitted and welded in  :grin:
Welding could be better but i think they are good enough and happy with them considering I'm a amateur
 :smiley:
Offline Diamond Hell
  • Opinions я Us
Looks good.... although I'd have welded them into the car tacked and then zipped them up in situ.
Let's hope the feet haven't distorted too much when you were welding them up.  :huh:
Offline golfyste
  • Project track car
I think they should be ok
Gave them plenty of tacking in opposite locations etc to try hold it in place and are welded both from and back so hope fully it will be ok..... Hopefully  :laugh:
And of they have I will make them work  :smiley:
Offline Dave_IOW
Looks good fella, I'd be happy with them :afro:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
Wow, only just spotted this thread. alot of hours gone into this.. can`t wait to see more progress..
i didnt realise fitting a cage was so much of a ball ache. :sad:
keep up the good work mate..
Offline golfyste
  • Project track car
Cheers man yeah I am just gonna go out and try fit them  :grin:
Yeah really getting the hours in now the weather has picked up a bit (aka not freezing to fetcher after 6pm  :laugh: )
It's not as much a balls he just takes some patience  :smiley:
Cheers dude  :smiley:
Offline golfyste
  • Project track car
There in!
Just need to be welded in and they are done.  :cool:
Then it's passenger seat bars, door bars and harness bar.
Is it ok to attach the harness bar too the cage in the same way as the door bars?
Need to order the bits for it then get it in!
Also gonna weld in some gussets/stiffeners around the cage (roof, pillars etc)
  • Opinions я Us
harness bars have a set of specs in the Blue Book.  Go by them.  Want to be welded in with the right strengthening.
Be very careful with that - you want to get it right and not transfer loads somewhere unexpected in the event of a crash.
Offline golfyste
  • Project track car
I have looked through but can only find spec of tube etc not mounting specs.
Will have another read.
Hmmm will have to have a think about it  :smiley:
Offline Dave_IOW
Do what we've done and stick in a brace between the rear turrets.
Seatbelts shouldn't be over a 15degree angle the book says, you also have loads of room for landings for the brace and will also stiffen up the rear end, considerably, by the accounts of someone down here that's already done it.
