Author Topic: seats subframes and exhaust  (Read 1371 times)
Offline vee-dub
« on: 16 January 2013, 12:39 »
is it easy to put mk2 golf seat subsframes on to mk4 golf seats and does a 16v 4 branch manifold go on toa 8v engine??
Offline antogoof
  • bbm mk2 g60
Re: seats subframes and exhaust
« Reply #1 on: 16 January 2013, 13:21 »
no. dont try. the bases are different. you need to cut off the bigger outer rear leg off the mk4 seats. they are 21" apart and need to be 19". so you need a grinder and a welder.
if you dont have these dont bother.
you can use standard mk2 seat bases from something like a driver? and fit mk3 gti seat foams and backs to them, this is a direct fit and you only need basic tools to do it.
i know cause ive done both conversions, the mk4s are better but the mk3s are easier. :smiley:
on the exhaust front, if it does not have a flexi in the manifold dont bother, i dont know about fitting though.
« Last Edit: 16 January 2013, 13:23 by antogoof »
mk2 bright blue met bits wanted in north west.
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 16 January 2013, 19:38 »
8V vs 16V have different port and bolt spacings.
Offline vee-dub
« Reply #3 on: 17 January 2013, 14:15 »
Thanks for the help and advice.
