Author Topic: Red lcd on speedo  (Read 1516 times)
Offline Jazz-blue-Wayne
Red lcd on speedo
« on: 16 January 2013, 09:21 »
Hi all can the red lcd screen on the speedo clocks be changed ?
As mine is going
My car bolf got 267bhp in my agu with a k04 convertion   piper x cold air induction kit, r-tech custom remap, custom down pipe and sports cat, milltek exhaust system, 4bar fpr, injectors off a ford f150 lightning pick
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Red lcd on speedo
« Reply #1 on: 16 January 2013, 11:33 »
Don't think so. You will need a new set of clocks. A cheap set of full FIS clocks can be had for about £50-80, then get em coded with MTE and lit needles  :wink:
« Reply #2 on: 16 January 2013, 12:03 »
Cluster repairs UK can repair the red lcd on them
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 16 January 2013, 12:30 »
Screens are available on eBay, they cost around £35
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #4 on: 16 January 2013, 14:04 »
If there is enough call for it I'd invest in some new equipment and do these for forum members :wink:
Offline scarr89
« Reply #5 on: 16 January 2013, 14:23 »
I was wrong. Ignore everything I ever post again  :embarrassed:
Offline Rob Zombie
« Reply #6 on: 16 January 2013, 14:44 »
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
« Reply #7 on: 16 January 2013, 14:56 »
Have you got a eBay number for the lcd screens
Offline Dan n Nic
« Reply #8 on: 16 January 2013, 17:40 »
Glad i saw this, i think mine is also on it's way out as flicks through, mpg, min, miles etc then goes dim then brightens up...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
