Author Topic: Does the AGU throttle body need adapting with vagcom?  (Read 1718 times)
Offline wotavudunn
can somebody tell me as i thought it was only electronicly opereated throttles.
Offline Screech16v
  • MK3 20vt AGU
Re: Does the AGU throttle body need adapting with vagcom?
« Reply #1 on: 14 January 2013, 22:23 »
I don't think so ,ive removed mine to clean it before and all I did was after refitting turn the ignition on and leave for around three mins then start it,was fine.
Offline Jin_C
« Reply #2 on: 14 January 2013, 22:43 »
Yes definitely, either Vag Com or disconnect the battery for a while.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline wotavudunn
« Reply #3 on: 14 January 2013, 22:45 »
well im going to pick my car up from a well respected vag specialist tomorrow as ive just had my inlet manifold changed and they have charge me £80 + VAT for changing my inlet manifold and adapting my throttle body. i told them the AGU throttle body dosnt need adaping as its cable operated not electric but the mechanic says it does.
Offline Kelvin1977
« Reply #4 on: 14 January 2013, 22:55 »
I am with you I thought no need to do anything on a AGU :huh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 14 January 2013, 23:55 »
I've had to do it before. Takes about 2 mins though. I would have changed it for less lol
Offline navmk4gti
« Reply #6 on: 15 January 2013, 01:37 »
No u dont. Just take one drive after 20-30 miles it will settle itself. Did throttle body clean on my previous AGU twice same way.
Offline golf-sib
  • Турботазик
« Reply #7 on: 15 January 2013, 01:51 »
With AGU the stock TB has a potentiometer and adjustment mechanism built in, typically when you put key in on position it will do an alignment and angle check. You can use vag com too, unless its causing a problem after a clean I wouldn't worry about it.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Chris.
« Reply #8 on: 15 January 2013, 17:08 »
Its certainly possible to align through VCDS.....but if it has solely been removed and re-installed you will be fine.
Click For Build Thread
Offline Kelvin1977
« Reply #9 on: 16 January 2013, 19:34 »
Decided to do this today and mine was fine no adjusting required  :grin:
