Author Topic: Noisey top end  (Read 1806 times)
Offline Dalo Harkin
Re: Noisey top end
« Reply #10 on: 15 January 2013, 13:38 »
I used dirko mate  :wink: the only thing I would say is the 2 middle bolts between the gearbox and sump hidden away ones are easy to get out a bit of an arse to get back in. You need a 5mm ball end allen key.
you can also get a 10mm socket on the outer side, I took all mine off with a 5mm allan key bit until someone on here told me a 10mm socket would do it, the bolts were that covered in crud, didnt even realise  :laugh:
Offline Kelvin1977
Re: Noisey top end
« Reply #11 on: 15 January 2013, 14:06 »
Yeah the outside ones are easy  :grin: it's the middle two someone said use a flexi joint but did not work for me. I have to say a lot easier with 10 mm socket
Offline Dalo Harkin
Re: Noisey top end
« Reply #12 on: 15 January 2013, 14:37 »
weird, mine went straight on, I know which ones you mean though  :smiley:
Offline Kelvin1977
Re: Noisey top end
« Reply #13 on: 15 January 2013, 14:40 »
Really might be different flexi joints  :undecided:But mines on  :smiley:
