Author Topic: Help needed!  (Read 4374 times)
Offline Tinkertaylor
Help needed!
« on: 13 January 2013, 15:30 »
Hi all, I'm a long time lurker and first time poster, so go easy on me!
Yesterday saw the arrival of my first mk6 gti (59 plate tornado red), and I couldn't be happier with it. Well maybe I could, so I could do with some advice...
Firstly, I've read a lot about iPhone compatibility with the vw Bluetooth. I have an iPhone 4 which will not (in any way) connect with the car. The phone doesn't discover the car, and if the car discovers the phone, it tells me it's not compatible. The wife's Nokia connects with no trouble, so what do I need to get the iPhone to work?
Secondly, I seem to be missing the compartment from the rear centre console (below the double air vents for the rear passengers). Can this be bought as a separate part? I don't even know what goes there!
Finally, does anyone have any recommendations for genuine mats? Mine are a little tired and I'd like to replace.
Thanks in advance for any advice...  :smiley:
MK6 GTI - Tornado Red - DSG - Monza Shadows - Heated Leather - Nav - Dynaudio - Parking Sensors - Bottle Opener!
Offline Cliff_944
Re: Help needed!
« Reply #1 on: 13 January 2013, 17:20 »
You cant connect to two phones at once - it looking for you wifes phone.  At the same time you get the car to look for another phone in settings, get the iPhone to look for the car, by going into general, settings, bluetooth and click on 'VW Phone'.
       GerTruDe - The GTD...
Offline Neil gti
Re: Help needed!
« Reply #2 on: 13 January 2013, 17:34 »
Welcome Tinks  :smiley:
Mine is a 59 plate with VW phone kit, it connected with my Nokia fine but would not connect to the iPhone,
I had to change the Bluetooth module under the front seat, no probs ever since, Got it off the forum and ebayed mine, will have a look through my messages etc see if I can find out module no:
There should be a pop out cup holder in the rear of the centre consul,
Id Get Genuine mats from the dealers,
Mk6 Gti Gone but not forgtten
Loving the 7R
Re: Help needed!
« Reply #3 on: 13 January 2013, 18:10 »
Cheers guys.
I've read a few threads on this forum about the Bluetooth module swap for iPhone compatibility. Any idea on cost? Would the same module be needed for the iPhone 5? I only ask as my upgrade is due in May.
I've just sourced some genuine black vw mats, £40 for a set of 4 (sounds reasonable).
I've scoured the 'net for the rear cup holder with no joy. Anybody out there got an idea on a product no? Otherwise i'll have to pop to the dealers to see if they can shed any light.
Cheers.
Offline Snapey070
Re: Help needed!
« Reply #4 on: 13 January 2013, 18:46 »
Cheers guys.
Go to stoke Volkswagen and tell them what part you want they pretty good at carrying stock.Im from Stoke and that's who I use for everything they ok.
Cheers.
Re: Help needed!
« Reply #5 on: 16 January 2013, 20:19 »
Thanks for the replies.
I'm making some progress: genuine mats purchased and in place, MID cables sorted, part number for the rear cup holder identified (I'll be giving stoke VW a call tomorrow to see what they can do), and bottle opener bought!
I've located a Bluetooth module that seems like it will do the trick (eBay item number 400390039845). It's described as plug and play, but is this really the case? Will it need to be coded in any way by VW?
Finally, the gromit that holds the string that supports the parcel shelf has broken on one side. It looks like the gromit is part of the plastic boot trim. Has anyone replaced this? The car is out of warranty so I don't suppose I've any chance of a freebie.
Cheers.
Re: Help needed!
« Reply #6 on: 19 January 2013, 14:32 »
Rear cup holder sorted, thanks to Premier VW in Leek. £50 all in, but I'm happier knowing it's how it should be. They also sorted me out with a new gromit for the parcel shelf - I have to drill the old one and push the new one through, but it beats buying the full trim.
Just bluetooth and iPhone to sort now. I'm bidding on a couple of modules online, so hopefully one will come through...
Offline EyeballPaul
Re: Help needed!
« Reply #7 on: 19 January 2013, 16:47 »
Are rear cup holders not standard on the mk6 GTI, on the pull down part below the rear vents?
Offline Mr GTD
Re: Help needed!
« Reply #8 on: 19 January 2013, 17:22 »
Yes they are std Paul but for some reason when Tinker brought the car they were missing....
Good to hear you've sorted it Tinks...
« Last Edit: 19 January 2013, 17:24 by Mr GTD »
Re: Help needed!
« Reply #9 on: 19 January 2013, 17:44 »
The guy I bought it from (who'd had it from new) said that one of his kids had broken it and he'd never bothered getting a replacement. Despite the fact it'll probably never be used, my OCD demanded that it was dealt with!
