Author Topic: arb bushes  (Read 1410 times)
Offline sharki786
  • GOT BOOST??
arb bushes
« on: 13 January 2013, 11:45 »
I think my arb is knocking as when driving at low speeds on very slightly bumpy rds i get a knocking noise. Now i have replaced nearly all of the bushes on the front apart from the subframe, steering rack & arb bushes.
Now my questions are is it worth me going poly bushes? I have poly bushed my wishbones. Do i poly bush the arb??? It is a standard arb not uprated.
Thanks
P.s what size do i need? 19mm or larger?
Cars mk3 gti 8v agg engine code
Thanks
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline tweed
Re: arb bushes
« Reply #1 on: 13 January 2013, 11:49 »
Not worth it with standard bar, its soft so why the need to tighten up the ends?
Offline spikenipple
Re: arb bushes
« Reply #2 on: 13 January 2013, 12:40 »
Have you checked that the drop links aren't broken or secured properly?
VW BUSH
Re: arb bushes
« Reply #3 on: 13 January 2013, 15:34 »
Quite common for these to snap, especially cheap welded items.
Often spin round and puncture the CV boot.....
Offline sharki786
  • GOT BOOST??
Re: arb bushes
« Reply #4 on: 13 January 2013, 16:19 »
Na i always get quality parts. I only replaced them 2 weeks ago after running around like a headless chikan as i didnt know what steering rack i have.
Ok il just get febi ones. Any other make i should look out for? Also what size should i get
*****MK4 GTI T*****
