Author Topic: rear end sliding  (Read 3901 times)
Offline pickles
  • Next!!!
Re: rear end sliding
« Reply #20 on: 13 January 2013, 12:52 »
Have you had the car properly aligned?
Low cars don't handle that we'll also.
Roads are bad at the moment
Sense.
Dropping the car moves the range the suspension works within, this can upset the handling no end.
Common misconception that lowering the centre of gravity automatically gives you better handling....
This.  I think Balance Motorsport looked at the MK4 and actually concluded that it handled better by being RAISED  :shocked:
had the fronts done few weeks ago after doing the suspension.
have been thinking about a 4 wheel laser alignment but was under the impression the rears cant be adjusted, or am i wrong.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Rhyso
« Reply #21 on: 13 January 2013, 12:55 »
Sense.
There is some adjustment in the rear beam I believe. Equally a proper 4 wheel alignment will check out your camber and castor etc etc. the kiwi fit type alignment is a waste of time IMO
Offline pickles
  • Next!!!
« Reply #22 on: 13 January 2013, 12:58 »
thanks, will maybe look into it, garage i used for my alignment just used the clamp on the wheel thingy.
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #23 on: 13 January 2013, 12:59 »
and money
Offline Rhyso
« Reply #24 on: 13 January 2013, 13:05 »
and money
That too  :smiley:
Offline pickles
  • Next!!!
« Reply #25 on: 13 January 2013, 13:09 »
thanks guys, think il get it sorted this week, sure theres a place near me that does it for £66 c/w computer printout :)
Mapped
Nearly S3 time  :)
Offline JC
  • Back in the North.
« Reply #26 on: 13 January 2013, 13:14 »
Offline pickles
  • Next!!!
Mapped
Nearly S3 time  :)
Offline Rob Zombie
« Reply #28 on: 13 January 2013, 21:48 »
this thread made me  :huh: then  :undecided: then  :shocked:
Good luck, sounds like your going to need it  :lipsrsealed:
Lol @ chuff
Pickles - sounds like your having fun mate :)
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline pickles
  • Next!!!
« Reply #29 on: 14 January 2013, 11:57 »
Lol @ chuff
as always ;)
Mapped
Nearly S3 time  :)
