Author Topic: rear end sliding  (Read 3900 times)
Offline barrym381
Re: rear end sliding
« Reply #10 on: 12 January 2013, 23:07 »
this thread made me  :huh: then  :undecided: then  :shocked:
Good luck, sounds like your going to need it  :lipsrsealed:
doesnt every1 that owns a mk4 need it   :smiley:
Offline JC
  • Back in the North.
« Reply #11 on: 12 January 2013, 23:11 »
nah, loads are selling up  :grin:
Offline barrym381
« Reply #12 on: 12 January 2013, 23:14 »
that says it all  :grin: :grin: so glad mine are long gone  :smug:
Offline tweed
« Reply #13 on: 12 January 2013, 23:15 »
Did you put the front wheels on the back?
High pressure in the rear will make it oversteer
If the front is a lot lower than the rear then that will give oversteer too.
Offline pickles
  • Next!!!
« Reply #14 on: 12 January 2013, 23:18 »
no same wheels went bk on .
filled the tyres with air that morning was only bout 32 in the rears tho which is fine im sure, did notice a slippery road sign the day after  :grin:
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #15 on: 12 January 2013, 23:19 »
lol dont you just hate P$%^KS like that ^^^^^^^^, sounds like your in need of much more luck than me ;)
« Last Edit: 13 January 2013, 10:02 by pickles »
Mapped
Nearly S3 time  :)
Offline tweed
« Reply #16 on: 12 January 2013, 23:27 »
Low cars don't handle that we'll also.
Roads are bad at the moment
VW BUSH
« Reply #17 on: 13 January 2013, 12:13 »
Sense.
Dropping the car moves the range the suspension works within, this can upset the handling no end.
Common misconception that lowering the centre of gravity automatically gives you better handling....
Offline pickles
  • Next!!!
« Reply #18 on: 13 January 2013, 12:36 »
Sense.
maybe better tyres needed with more grip ?
Mapped
Nearly S3 time  :)
Offline Rhyso
« Reply #19 on: 13 January 2013, 12:41 »
Have you had the car properly aligned?
Sense.
This.  I think Balance Motorsport looked at the MK4 and actually concluded that it handled better by being RAISED  :shocked:
