Author Topic: How do you tell how low your car is?  (Read 5267 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 22 July 2005, 20:20 »
When i got mine it has been lowered. but i have no idea how low.
I measured from the bottom of the side trim (below the door) and the gap to the floor is 16.5cm, can anyone tell me form this how low it has been lowered?
Offline golfgti818
Re: How do you tell how low your car is?
« Reply #1 on: 22 July 2005, 22:39 »
You measured in the right place but you need to compare measurement with a standard height gti. Cant help you there because mine is lowered 60mm. But i think most gtis get lowered 40mm on average.
Offline Deefadog
« Reply #2 on: 23 July 2005, 08:55 »
Cheers, just thought aswell, i have 16" alloys and 40mm profile tyres, so that's going to add to the calculation :)
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 23 July 2005, 17:19 »
the 40 in your tyre size isn't 40mm, it's 40% of the width...
Offline Deefadog
« Reply #4 on: 23 July 2005, 21:02 »
Now i am confused!
mix
« Reply #5 on: 23 July 2005, 21:26 »
OIf you have to jack the car up to do an oil change, then you know its looooowwwww :cool:
Offline theviper
« Reply #6 on: 24 July 2005, 08:32 »
what Dizzie means the numbers on the tyre are ie 205/40/17 is  205 is the width of the tyre the 40 is 40% of 205 which is 82mm high of the side wheel and the 17 is the size of the wheel
Pete :evil:
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« Reply #7 on: 24 July 2005, 09:12 »
hi all
just got my Mk2 f reg gti its not lowered yet. it measures 230mm from the bottom of the sill to the floor.
hope this helps
Jase555
Offline jase555
« Reply #8 on: 24 July 2005, 09:14 »
oh yeah forgot to say that also on standard wheels and tyres
Jase555
Offline Deefadog
« Reply #9 on: 24 July 2005, 11:46 »
Thanks guyz,
Jase, what is the size of the tyre you have? if i can have this i.e 185/50/15 then i can calculate mine :)
So does this sound like the right calculation -
Standard - 230mm
Mine - 165mm - 25mm (for the 16" to 15" alloy) = 140mm + standard tyre difference to 86mm (my tyre height) = My lowered amount?
Sound right?
