Author Topic: Changing Oil pressure switch Easy diy job?  (Read 1229 times)
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
« on: 12 January 2013, 12:31 »
Any advice on how to replace my oil pressure switch the one on the oil filter housing as found mine has a small leak this morning.Easy diy?Do I need to use any torque values or not?Any useful advice would be much appreciated.Thanks Lee
Offline Abf83
  • Mk3 16v Alpine White
Re: Changing Oil pressure switch Easy diy job?
« Reply #1 on: 12 January 2013, 13:04 »
very easy to do m8 , just done both of mine. just make sure to not over tighten as you could strip the thread and if you are replacing both just make sure to have the correct wires on the switches.
Offline Leebob
« Reply #2 on: 12 January 2013, 13:14 »
From what ive read on a search i need the 1.8 bar switch which is white
Offline Leebob
« Reply #3 on: 12 January 2013, 13:18 »
Anyone know where to buy a quality switch from?Ecp any good?
Offline itavaltalainen
« Reply #4 on: 12 January 2013, 14:15 »
ecp, gsf, vag, volksbits, ...... list is long.
would just go to nearest car parts place and have a look at the switch and buy one that's made in europe...
febi, topran, qh ....
Offline Jasikasisback
« Reply #5 on: 12 January 2013, 17:14 »
take old switch off and look at the bar range. make sure your replacement switch is the same range as if not it will blink on your dash and it is really annoying:)
