Author Topic: Big turbo/fueling/mapping?  (Read 5191 times)
Offline jonrandom
« on: 11 January 2013, 20:13 »
Ive got a Agu and im getting it sorted to run a big turbo, at the mo ive got the standard injectors on along with the standard sized diameter maf housing.
My question, can I put on the bigger injectors as long as I scale up the maf diameter as well? can the ecu take that into account and run ok? or should I wait until the tuners fit them?
Ideally id like to fit them both now but dont want to do damage and get bore wash or anything like that as the engine has now only done about 100 miles since rebuild and slowly breaking it in to get mapped.
Offline Chris.
Re: Big turbo/fueling/mapping?
« Reply #1 on: 11 January 2013, 20:20 »
Chuck em in when you get mapped.
What turbo?
Click For Build Thread
Offline Dave_IOW
« Reply #2 on: 11 January 2013, 20:36 »
He has a TD05 16g from an evo.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline barrym381
« Reply #3 on: 11 January 2013, 20:37 »
What turbo?
sure its a td05 he has stuck on it  :evil:
Offline jonrandom
« Reply #4 on: 11 January 2013, 20:38 »
Fair play, just wanted to get them in there and get it all sorted.
Turbo the TD05 big16G
Just want to get everything ready
Offline jonrandom
« Reply #5 on: 11 January 2013, 20:39 »
What turbo?
Yep :smiley:
Offline Dave_IOW
« Reply #6 on: 11 January 2013, 20:40 »
I read somewhere that if you kept the proportions right with MAF housing and injectors, it was relatively safe to do, however going from 2.5 ID to 2.75 ID (vr6 housing) doesn't give you much scope for larger injectors anyway, until it's mapped of course.
Offline jonrandom
« Reply #7 on: 11 January 2013, 20:48 »
I read that some where as well which is why I'm asking, ive got a 3.25 intake and either 440 bosch and adjustable fpr or siemens 630, to get the max out of the setup
Offline jonrandom
« Reply #8 on: 11 January 2013, 20:52 »
But as dave said if you keep in the scale between them both is it ok?
Offline Dave_IOW
« Reply #9 on: 11 January 2013, 20:56 »
I believe it is as they correct themselves out, aslong as you could get them pretty damn close, I think you'll be OK.
Disclaimer: I will take no responsibilty for any engine damage caused by this   :grin:
