Author Topic: Dirty Vibration  (Read 1525 times)
Offline Adz Gti
  • Instagram - gti_adz
Dirty Vibration
« on: 11 January 2013, 18:40 »
Guy's i need help asap, i've already been through 2 driveshafts. The problem is since i have had my golf lowered on JOM coilovers the front left wheel and what seems to be the driveshaft or track rod arm/end vibrates hard, at slow speed of say about 10/20mph is ok anything above it vibrates.
I've had the drivers side notched for future air ride and i've had the standard ARB cut out and the eibach ARB put in.
When checking 12-6 movements for bearing, it doesnt seem like it is, i'm not sure if should change the track rod arm/end and bearing. If this has happend to anyone, would be great to get some sort of help.
Just Daily Dubbin
Offline DubAndDubber
Re: Dirty Vibration
« Reply #1 on: 11 January 2013, 23:56 »
Does it sound like an intermittent knock?
Mk5 Golf Gti 06'
Offline Adz Gti
Re: Dirty Vibration
« Reply #2 on: 12 January 2013, 02:19 »
errrm its like somethings hitting which is causing the vibration, however when my mechanic checked it, everything was fine, took the front axle off and couldn't spot anything that could have been hit  :cry: i fckn give up
Just Daily Dubbin
Re: Dirty Vibration
« Reply #3 on: 12 January 2013, 13:19 »
My bet would be the Jom coilovers. Infamous or failing as the locknut comes lose and taps on the shock itself. I replaced mine last month and refitted with loctite.
Mk5 Golf Gti 06'
Offline Adz Gti
Re: Dirty Vibration
« Reply #4 on: 14 January 2013, 16:17 »
i've also done this, its not the shocks  :sad:
Just Daily Dubbin
Offline Ashmond
  • Money, b!tches And Boost
Re: Dirty Vibration
« Reply #5 on: 14 January 2013, 16:32 »
what sort of noise, if its a whiring noise and gets more frequent with increased speed its your bearing, I changed mine two months ago and was so much better. Hard to tell without being more specific?
Offline Adz Gti
Re: Dirty Vibration
« Reply #6 on: 15 January 2013, 01:42 »
no whiring noise, it sounds as if there contact when turning right but left is fine, anything over thirty the vibration begins but theres no play in the wheel, hub im confused
Just Daily Dubbin
