Author Topic: Top end rebuild  (Read 1597 times)
Offline Abf83
  • Mk3 16v Alpine White
Top end rebuild
« on: 11 January 2013, 17:11 »
Anyone got a rough idea on the cost of a topend rebuild on an 16v abf?
Offline leigh_harty
  • Audi AGU
Re: Top end rebuild
« Reply #1 on: 11 January 2013, 17:19 »
Buy yourself a head - rebuild & learn  :smiley:
Whats up with yours?
Dont lose your dinosaur!
Offline markrtw
Re: Top end rebuild
« Reply #2 on: 11 January 2013, 17:20 »
New head gasket, cam followers, valve guides & seals, reground valves, skimmed head plus other gaskets/seals on a 16v plus you should do the the cam belt & chain & tensioner as they are off. Easily a Grand plus for a proper job. If tight on cash, could reuse the cam followers if they are OK and reuse the cam belt & tensioner if recent, but I would still replace the chain as the cams are out, but over all it would not save you a lot.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Top end rebuild
« Reply #3 on: 11 January 2013, 17:30 »
I was considering this option myself actually.
Offline Abf83
Re: Top end rebuild
« Reply #4 on: 11 January 2013, 18:49 »
I was just thinking worse case scenario. But basically im getting tapping from the topend . Ive changed the sensors and oil light is fine and replaced oil and filter engine flush and slick50 .ive also changed oil pump along with a new sump gasket and sump plug. The tapping only really starts as its warming up. Its not burning any oil so im hoping its just the lifters.
Offline sharki786
  • GOT BOOST??
Re: Top end rebuild
« Reply #5 on: 11 January 2013, 21:32 »
If the engine is healthy then change the tappets mate. No point getting a topend build its just uneconomical
*****MK3 Anniversary*****
*****MK4 GTI T*****
