Author Topic: What have you done to your Mk6 today then?  (Read 1622409 times)
Offline david25
Re: What have you done to your Mk6 today then?
« Reply #3040 on: 25 August 2020, 19:26 »
Do you think its worth using a trim removal tool to lever it up? By hand it feels welded on.
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3041 on: 26 August 2020, 09:15 »
As the top bit that covers the jet had half broken off mine I sprayed some wd40 down the sides. Try moving the side outwards alittle and move it up and out at the same time once you get it moving. You should be able to see how its held by looking at the new one and comparing were it goes on the wiper arm.
Current Garage:
35+ years of GTI ownership.
Offline david25
« Reply #3042 on: 26 August 2020, 15:25 »
Thanks for the advice, will attempt again at the weekend
Offline david25
« Reply #3043 on: 31 August 2020, 07:52 »
Quick update, I think the best way is to use an angled trim removal tool and lever up from the top or bottom which will release the two clips that hold it on.
Offline Borbus
« Reply #3044 on: 31 August 2020, 12:10 »
Since you've mentioned yours I've noticed mine is very sun faded too. Might get a new one too. Has anyone tried treating their other black plastics like the triangle near the wing mirrors or the window seals? All looking a bit grey.
2010 Mk6 GTI
Offline david25
« Reply #3045 on: 31 August 2020, 12:19 »
Haven't investigated the mirror plastics.
The part for the wiper cap is 5K6955435 you will find a mix of genuine and copies on ebay
Offline david25
« Reply #3046 on: 01 September 2020, 19:35 »
For my next problem; has anyone encountered a smell of petrol after driving and then parking?
Its coming from the rear quarter near on the side of the filler cap.
See this post http://www.golfgtiforum.co.uk/index.php?topic=275939.0
Do you know where this breather pipe is located?
Offline ramrod
« Reply #3047 on: 04 September 2020, 16:53 »
David have you had any codes? i experiencd this until i got my purge valve changed, its ok now, no petrol smell
Mk6 Gti - current daily
Mk3 16v Anni - retired daily now parked on 200,300 miles
Offline david25
« Reply #3048 on: 05 September 2020, 16:36 »
Err no, there are no engine lights on but I do have a cheap bluetooth reader I can find (somewhere) and install Torque light to check. What codes or engine lights did you have?
In the meantime I have installed a new fuel cap, the rubber seal was slightly broken in two places, just like in the link above.
Also, can you give me some more details on your purge value location or part number?
« Last Edit: 05 September 2020, 16:42 by david25 »
Offline ramrod
« Reply #3049 on: 06 September 2020, 20:40 »
PO441 was the error code & the purge valve is right at the front of the engine, you cant miss it lol
got a link to the fuel cap you got?
