Author Topic: What have you done to your Mk6 today then?  (Read 1622410 times)
Offline DUBbleChin
Re: What have you done to your Mk6 today then?
« Reply #3030 on: 14 August 2020, 13:26 »
Yeah I looked at the vids on YouTube too.
I did it just for the updated look really. I like the digital displays as they remind me of JDM Honda & Nissan from the 90s... Which I used to be into.
All of the functions work as they should, surprisingly!
Nov '11 Candy White GTI, 5dr, heated leather, Rns510, DCC, Revo stg. 1, Sachs clutch, MST cai, Jetex 3" cat back, H&R springs, 19" TSW
Offline david25
« Reply #3031 on: 24 August 2020, 17:21 »
Hi everyone, do you know how to remove the rear wiper cover? I have a replacement because my one is sun bleached.
Youtube suggests it should pull off, but its jammed on tight!
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline ramrod
« Reply #3032 on: 24 August 2020, 19:42 »
thought it was just push & pull? on a sidenote, does the car have to be put into service mode to change the front wipers?
Mk6 Gti - current daily
Mk3 16v Anni - retired daily now parked on 200,300 miles
Offline Borbus
« Reply #3033 on: 24 August 2020, 21:04 »
You have to put the front wipers into the service position to be able to lift them up, yeah. I forget every time I wash the car. Turn ignition to position 2, then off again, then push wiper stalk down to activate service position.
2010 Mk6 GTI
Offline SRGTD
« Reply #3034 on: 24 August 2020, 21:27 »
Once the wipers are in the service position and lifted away from the screen to be able to remove the old / fit the new wiper blades, I’d recommend laying something like a thick towel on the screen, in case the wiper arm falls back down onto the screen after the old blade’s been removed. If it does do this and nothing’s been put on the glass to protect it, the metal end of the wiper arm can crack the windscreen.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline ramrod
« Reply #3035 on: 24 August 2020, 21:37 »
glad i asked now! thanks guys, would be typical of my luck to crack my windscreen while changing the wipers lol
today i topped up my oil with 5-40 fully synthetic & i used obdeleven to set my digital speedo in the dash, much prefer that to the stupid km/h display that was there before :cool:
Offline david25
« Reply #3036 on: 25 August 2020, 08:15 »
Sorry, its this bit, how do you remove it?
Offline SRGTD
« Reply #3037 on: 25 August 2020, 09:33 »
According to the instructions at the link below, it should unclip.
https://workshop-manuals.com/volkswagen/golf-mk6/vehicle_electrics/electrical_system/windscreen_wipe/wash_system/rear_window_wiper_system/removing_and_installing_wiper_arm/
If you can’t remove it, you could always consider reviving the colour of the existing cover with one of the many plastic trim dressing products on the market. Alternatively, you could paint it, although you’d probably need paint that’s specifically for use on plastics.
Offline david25
« Reply #3038 on: 25 August 2020, 10:58 »
Thanks for finding that, will try and lever it towards the wiper blade as show in the diagram. It definitely doesn't "unclip" but its been on for nine years...
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3039 on: 25 August 2020, 13:42 »
It lifts up and pull it out from the round section bit but you have to sort of hold the wiper partly up to get it out. It can get stuck due to corrosion of the wiper nut. It is a bit fiddly replaced my leon one which is the same not long ago as i stupidly cracked the top bit when washing the car.
« Last Edit: 25 August 2020, 13:44 by Snoopy »
Current Garage:
35+ years of GTI ownership.
