Author Topic: What have you done to your Mk6 today then?  (Read 1622570 times)
Offline seabrook132
Re: What have you done to your Mk6 today then?
« Reply #2960 on: 01 May 2019, 17:08 »
Fitted a Bluetooth module and coded it. Gives me voice recognition for the phone for dialing and music :smiley:
For anyone interested this is what I did.
Volkswagen 9W7 Bluetooth Coding for MK 6 GTI MY 2010
With this retrofit I am able to pair my phone with the car and use hands free to make and receive calls and use voice to control the phone. The phone book appears in the DIS and can be controlled via the buttons on the steering wheel. The microphone in the overhead console is used.
The original configuration that I have in the car (MK 6 GTI MY 2010) is:
RCD310 (DAB) radio part number 1K0 035 186 AB
MDI part number 5N0 035 342
Multi-function steering wheel with cruise control.
White DIS.
I installed an OEM Bluetooth module (wiring instructions are below the coding instructions)
Part number: 7P6 035 730 F
Initial coding in CAN gateway address 19: Bring up the installed list and tick 77 telephone.
Coding using VCDS for telephone address 77:
My coding: 0200000000010110
The multi-function steering wheel also needs re-coding address 16:
Original code: 0000532
New code: 0000732
The change of the code is required to activate the microphone button on the steering wheel as it was only a mute button originally. This provides voice recognition for the phone for dialing, music etc.
(Note that the socket configuration for the RCD310 and RNS310 are identical)
The total cost was £115.
I bought a harness from carsystems.pl  with postage was £35.00 The harness bought included all the wiring for the MDI and Bluetooth module as this did not require any extra wiring (It was plug and play and included SDS cabling for head units with voice control eg RNS510)
Combo Kabelset VW Bluetooth 7P6035730 + MDI 5N0035342 ► ULTRA Plug & Play SDS
Useful installation instructions at:
https://carsystems.home.pl/instrukcje/bluetooth%20golf%20VI.pdf
and at
https://www.carsystems.eu/bluetooth-wiring-connection-scheme-sds-functionality-how-to-connect,b18.html
The new cable for the MDI was routed through the central console alongside the front cup holder. I found it easier to remove the rear cup holder and surrounding trim to pull the cable through. The Bluetooth cable and microphone were routed as per the carsystems instruction.
The bluetooth module came from ebay £71.00
The microphone labelled as a Skoda harness on ebay was half the price of the advertised VW microphone and is exactly the same at about £7.00 and came with cabling that was not required.
That's useful info, cheers Joe!
This is something I have always wanted to do to my car, but haven't been able to justify yet. I have bluetooth in my car, but it's a Volkswagen accessory system which uses a little screen stuck to the dash which I hate. It works though, so I haven't found an excuse to bin it yet and get the integrated module.
What kind of phone are you using with it? Have you tested playing music over bluetooth?
That seems like a great price for the retrofit!
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #2961 on: 01 May 2019, 17:20 »
Thanks and very useful info. Something ive always mentget round to do too.
Current Garage:
35+ years of GTI ownership.
Offline joe6
« Reply #2962 on: 01 May 2019, 19:40 »
Yes does play music from the phone. Using a basic touch screen android phone version 4.4.2 with 500MB storage from 2016. Not explored it all yet so do not know if you can select music or if it just plays in file order. Tend to play music from a data stick through the MDI so more research yet to do!
Offline jord91
« Reply #2963 on: 16 June 2019, 22:27 »
In my GTi mk6 Noticed recently that I am get a buzzing/rattling sorta sound coming from drivers side dash area
It only happens between 2000-2200rpm in gear when the car is decelerating.
Any ideas what it is
Offline G-Unit13
« Reply #2964 on: 26 July 2019, 16:43 »
Changed the cruise control switch. It is the same as the mk5 - just a single stalk on my 2010 MK6. Original went faulty with an ! in the instrument panel. New one cost me £25 and an hour of my time to fit.
Wish it was that simple on my 2011. Doesn't have cruise control from factory but instead of just changing the stalk like on earlier cars I'd have to change both stalks and slip ring to retrofit it. Makes it way way more expensive than it would be to retrofit to an earlier car! Damn VW!
I actually bought a cruise control stalk ready to fit before realising I had the updated components. Luckily I managed to get the money back on eBay.
Did you manage to get the Cruise control working? I’m attempting to get it done but need to change the slip ring but don’t know the part number for the slip ring I need.
Thanks
2016 Golf GTi Performance
Offline joe6
« Reply #2965 on: 27 July 2019, 16:49 »
Thanks
This link may help. You need to look at the 5k list.  http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Offline G-Unit13
« Reply #2966 on: 31 July 2019, 13:04 »
Thanks
Thanks will look into it.
Offline G-Unit13
« Reply #2967 on: 04 August 2019, 15:46 »
Looking to retrofit power fold mirrors to my 2012 GTi
Apart from the mirrors and switch do I need anything else?
Thanks
Offline joe6
« Reply #2968 on: 04 August 2019, 20:56 »
Thanks
You need to check that the door control units are compatible.
Edit: If you can find someone with power mirrors fitted then get a VCDS scan from them with module part number and see if they match your modules for compatability. This link may help: https://forums.ross-tech.com/showthread.php?12182-MK6-Golf-GTI-Auto-Folding-Mirrors
« Last Edit: 05 August 2019, 12:20 by joe6 »
Offline wasp
« Reply #2969 on: 19 August 2019, 10:26 »
Service
New Potenza's,replaced the 235's with 225's,far more responsive to steering input !!
Wheel alignment
Checked tensioner,it is the upgrade :grin:
Love it  :kiss: :kiss:
