Author Topic: What have you done to your Mk6 today then?  (Read 1622639 times)
Offline seabrook132
Re: What have you done to your Mk6 today then?
« Reply #2940 on: 08 November 2018, 08:57 »
Now that’s impressive David! I wasn’t trying at all on Monday when I took that shot but even with trying I haven’t seen an average above 43 - 44ish. I tend to average 32 - 34 most of the time.
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline Charliemk6
« Reply #2941 on: 13 November 2018, 08:18 »
I think I may have issues then as I'm lucky to get over 25 on the motorway and under 20 on the urban commute???   :sad:
Offline david25
« Reply #2942 on: 16 November 2018, 09:33 »
Car trouble today; engine management light, rough idle, white smoke.
Being recovered, any ideas? I guess a chain problem would mean no start.
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #2943 on: 16 November 2018, 13:30 »
Sounds more like turbo fail
Current Garage:
35+ years of GTI ownership.
Offline david25
« Reply #2944 on: 16 November 2018, 17:03 »
I would be upset at 44,000 miles, full history.
Its seven years old, any hope of good will?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #2945 on: 16 November 2018, 19:46 »
Wouldn't think so from VW unless you have the extended warranty.  If you have used the same Dealers they may give you a good will for loyalty but it may still be more expensive than a specialist would be. A good master tech and/or diagnistics will be able to diagnose the cause.
Current Garage:
Offline david25
« Reply #2946 on: 22 November 2018, 18:01 »
Dealer states: problems with cylinder 3 and 4, possibly locked injector?
However, fault cannot be replicated from cold this morning, so collecting tomorrow with the £60 diag fee.
So, what causes this? bad petrol, carbon deposits, failing injectors?
Should I be thinking of paying £350 for the VW extended warranty?
https://insurewithvolkswagen.co.uk/extended-warranty
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #2947 on: 23 November 2018, 11:56 »
Ask them for a copy of the diagnostic report as it should have logged fault codes. Then from the fault codes you could find a lists of maybe probable causes.
A vw specialist maybe a better bet than a main dealer as they will probably have seen this before and will know how to diagnose faults
Current Garage:
Offline joe6
« Reply #2948 on: 29 November 2018, 12:00 »
Just got back from Cornwall - average speed 61mph and 38.1mpg on 332miles. Started on a full tank and saying 100miles left! Just about all on dual carriageway and motorway so fairly steady cruising but some stop start in M5/M6 roadworks. Think you may have a problem Chaliemk6. Could it be a strong right foot? :smiley:
Offline mermade
« Reply #2949 on: 04 December 2018, 11:48 »
Finally got around to replacing my worn wishbone bushes to powerflex ones, got a great deal on black friday ! https://powerflexstore.co.uk/volkswagen/golf-mk6-5k-2009-2012/powerflex-front-wishbone-rear-bush-golf-mk6-5k-2009-2012-pff85-502/
