Author Topic: Noise when pulling away in first gear  (Read 3673 times)
Offline Kelvin1977
« on: 11 January 2013, 14:59 »
Hello can someone help I have a 1998 Mk4 AGU Turbo I have a noise when in first gear. At tick over and every other gear perfect no noise. The way to describe it would be a rumble help please ?
Offline Mach 5
Re: Noise when pulling away in first gear
« Reply #1 on: 11 January 2013, 15:12 »
That will be a bearing gone inside the gearbox.
Offline Kelvin1977
« Reply #2 on: 11 January 2013, 15:15 »
I thought someone would say gearbox I have never heard of anything like it before. Like I said as soon as you are in second quite as a mouse
 :undecided: Looks like a Change of gearbox then
Offline rio_gti
« Reply #3 on: 11 January 2013, 15:36 »
time for a 6 speed  :wink:
Offline Kelvin1977
« Reply #4 on: 11 January 2013, 15:41 »
If I didn't have a 5 speed here it would be  :grin:
Offline Kelvin1977
« Reply #5 on: 14 January 2013, 20:47 »
Ok its getting a bit worse first gear the same but the clutch seems low biting point and not have same noise low revs in others gears still gearbox or clutch ? What are the symptoms of a dual mass flywheel and clutch going ?
« Reply #6 on: 14 January 2013, 21:10 »
Could be the flywheel or maybe a cv joint.
Offline Kelvin1977
« Reply #7 on: 14 January 2013, 21:22 »
99% sure not a cv Joint but I am thinking flywheel but does that not make a noise when clutch down ?
Offline Mach 5
« Reply #8 on: 14 January 2013, 21:43 »
Hmmm... I'd say throw out bearing which means a new clutch assembly.
You'll have to get a car mechanic to have a listen to the noise to be sure. But the fact it's only in first gear narrows it down somewhat.
Offline Kelvin1977
« Reply #9 on: 14 January 2013, 21:57 »
No too be honest was going to take it somewhere tomorrow I have a spare gearbox here so if its that not a problem lol
