Author Topic: 96 Anniversary 16v Engine stutter/cutting out  (Read 2201 times)
Offline markrtw
« on: 11 January 2013, 09:46 »
I have a little problem with my mk3 16v (ABF) I was wondering if anyone could help with.
When cold it often stutters when the oil temp is reading (on the MFA) 70-74 degrees and then it goes away again.
It has not happened below that temp and not once up to full temp.
I have found the following code with VAG-COM:
00513 -  Engine Speed Sensor (G28)
        27-00 -  Implausible Signal
But I wondering if this could be a red herring due to the limited temp range the issue happens over and was wondering if it could be with a temp sensor.
Your thoughts please?
Offline Callum_K
Re: 96 Anniversary 16v Engine stutter/cutting out
« Reply #1 on: 11 January 2013, 12:15 »
It will be the speed sensor, otherwise known as the crank sensor. I just replaced mine, the wiring is prone to breaking where it runs so close to the engine. About £60 for a decent part and easy to fit if you have some axle stands and a jack. You have to remove the starter motor and front engine mount to gain access.
Offline spikenipple
« Reply #2 on: 11 January 2013, 17:41 »
Definitely the crank sensor. I replaced mine in a couple of hours with plenty of tea breaks  :wink:
This is the part I bought, on eurocarparts.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1996/p/car-parts/engine-parts/fuel-and-engine-management/engine-management-sensor/?494440201&1&6948725f83bc62765a07d54d4fa1915003f7ee02&000440
