Author Topic: Gear stick  (Read 1647 times)
Offline navmk4gti
Gear stick
« on: 11 January 2013, 00:27 »
Anyone know the size of mk4 gear stick. Is it m12x1??
Offline navmk4gti
Re: Gear stick
« Reply #1 on: 11 January 2013, 10:58 »
Someone must know :grin:
Offline stfc_gti
Re: Gear stick
« Reply #2 on: 11 January 2013, 12:03 »
what exact bit do you mean?
2002 1.8T GTI AUM, Standard (not for much longer)
Offline navmk4gti
Re: Gear stick
« Reply #3 on: 11 January 2013, 12:15 »
The gear stick the metal rod where gear knob goes on too :smiley:
Offline brewey
Re: Gear stick
« Reply #4 on: 11 January 2013, 15:33 »
If you're after a different knob I think most of the VAG range fit. I need to sort one after doing be vinyl wrapping you linked me.
2000 1.8T ARZ - OEM+
Offline brewey
Re: Gear stick
« Reply #5 on: 11 January 2013, 17:11 »
When I say most I mean from the same time frame as the mk4 and newer.
Offline navmk4gti
Re: Gear stick
« Reply #6 on: 11 January 2013, 17:49 »
Dnt want vag gear knb bud thats why needed the size.Yup its since done my vinyl wrapping that the gearknob is annoying me. That wood :sick:
Looks like m12. And cant be bigger then 1 in diametre  :undecided:
Offline topher
  • Administrator
  • fully functioning
Re: Gear stick
« Reply #7 on: 11 January 2013, 20:19 »
its not m anything, its not threaded
Offline beppe2672
Re: Gear stick
« Reply #8 on: 11 January 2013, 20:29 »
It's clip on, If you lift your gater up and have a look you'll see what I mean.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline Rob Zombie
Re: Gear stick
« Reply #9 on: 13 January 2013, 12:26 »
I've just fitted a momo gear knob - it just slotted over the top and used and tightened it up with Allen :)
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
