Author Topic: Engine removal question  (Read 2237 times)
Offline molegti
« on: 10 January 2013, 19:05 »
is it possible to remove the engine with the gearbox in situ or has the whole lot definately have to come out and be split?
Offline mad4vws
Re: Engine removal question
« Reply #1 on: 10 January 2013, 19:29 »
both can be removed together if you use a engine Crane or hoist.. :wink: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline richking
« Reply #2 on: 10 January 2013, 23:00 »
I took mine out last month with a crane and i left the box on. all i did was pull the cambelt side forward as it came out so the gearbox cleared the chassis leg.
Offline molegti
« Reply #3 on: 11 January 2013, 17:56 »
thanks for the replies but im thinking more along the unlikely lines of can the engine be remove without bringing the gearbox with it?
« Reply #4 on: 11 January 2013, 23:38 »
Yes but it makes it harder, just as quick to remove both together and then split on the floor.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 11 January 2013, 23:41 »
Why would you leave the gearbox in if you're taking the engine out,  its easier to leave it bolted together.  :huh:
Offline molegti
« Reply #6 on: 11 January 2013, 23:46 »
Less to remove assuming its practical or even possible.
Offline weazgti
« Reply #7 on: 12 January 2013, 15:07 »
It won't make it easier. You d have to remove box from car then pull engine which will be a waste of time
Offline molegti
« Reply #8 on: 14 January 2013, 08:54 »
Thanks for the replies, just planning ahead at this stage.
