Author Topic: brake pipes & the nipples.  (Read 6268 times)
Offline sharki786
  • GOT BOOST??
« on: 09 January 2013, 20:37 »
Who has replaced their brake pipes with copper pipes?
What size nipples did you use? :grin:
How much did you pay for the nipples? :grin:
How much did you pay for the copper pipe?
What diameter size pipe did you use?
How many meters of pipe did you use?
Last of all where did you buy them from?
My car is mk3 gti 8v P reg.
Front calipers are ATE rears are LUCAS.
Sorry for all questions.
Thanks
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: brake pipes & the nipples.
« Reply #1 on: 10 January 2013, 08:52 »
No one has replaced thier brake lines?
*****MK4 GTI T*****
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2 on: 10 January 2013, 09:24 »
Yea but can't remember haha
Got new nipples at audi for my S3 front calipers they were about £6 I think
Got rear ones at Vw ( got mk4 rear brakes)
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 10 January 2013, 10:13 »
Thanks kells.
Will be paying them a visit tomorrow
*****MK4 GTI T*****
Offline gazpowells
« Reply #4 on: 10 January 2013, 13:34 »
If you remove old pipes off and take them your local motor factors they should have no problem making you new ones
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 10 January 2013, 14:22 »
Making pipes is easy as i did some for a bm 36 (p plate) last week as my mate has the tool. Spoke to another mate about the size of the pipe & he said 0.7-0.9?
Andrew page do 25ft of copper pipe for £8 all in on trade price.
Will be doing them this weekend or next as i got my rear yellow stuff pads & last night ordered my front yellow stuff pads just waiting for someone to reply back on thw discs.
Will be doing a full brake build. Will also refurb my calipers with new seals & new lick of paint.
Cant wait. :grin:
*****MK4 GTI T*****
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #6 on: 10 January 2013, 17:42 »
What you need is:
At least 25ft - 3/16 Outside Diameter 22 Gauge Copper Brake Pipe
M10 x 1mm Male Brake Pipe Ends (10 should do)
Also some of the pipes that come from the ABS pump ( 2 i think) will have M12 x 1mm male ends so you will need some of these also.
Shouldn't cost more than £20
When I done mine I got all the stuff from the BEAL WORKSHOP SUPPLIES website.
http://www.beal.org.uk/automotive/brake-pipe-nuts/cat_68.html
You are familiar with the processes involved in making brake pipes yeah?
Also check the condition of the rubber flexi pipes on the car as they may need replaces if the rubbers perished or the ends are rotting. You will probably need around £40 for new ones of these from a local motor factors.
« Last Edit: 10 January 2013, 17:45 by Gti_Jamo »
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 10 January 2013, 21:07 »
3/16 Outside Diameter 22 Gauge could you explain what this means?
Thanks for the info peeps.
Will be replacing the hoses with braided demon tweeks or goodrich hoses. :cool:
*****MK4 GTI T*****
Offline Gti_Jamo
« Reply #8 on: 10 January 2013, 21:14 »
Its the size and thickness of the pipe. Also those M10 x 1mm  pipe ends I said above you would need 10 but think u may need
12 of them.
Offline mercedeslimos
« Reply #9 on: 01 November 2013, 23:47 »
Are all the pipes on a MK4 12x1mm pitch? Reason is I'm using MK4 Master cylinder and ABS pump in my MK2 with G60  front Brakes and MK2 conversion hoses on the rear. So at all 4 wheels I need M10x1mm nuts, but the MC looks bigger, as does the ABS pump. Anybody know where I could get an adapter M12x1 female>M10x1 male and use the MK4 hoses re-shaped rather than making new ones.
Sam
